Does anybody know anything about the TR-3160? It looks like another potential option, used in the ATS from '13 on, also under $1,000 for a unit with under 60k on it. Looks like you can get a yoke adapter that bolts on to the output flange to be able to use a slip style driveshaft. Though the starter provision is on the wrong side of the bellhousing. The ratios look a little better than the AY-6.
So working out some of the costs, just to get a ballpark, has anybody had to get a custom (not a special racing super strong version) slip-style driveshaft? I would ballpark that around $400-$500, based on what you can get one custom made for a truck at one of the online places. Unless there's a good reason not to use an adapter on the block, I'd probably have to pay a machine shop to get the dimensions of the bellhousing bolt pattern relative to the input shaft centerline (unless that info is online already), then waterjet an adapter plate and get a custom clutch. I can get the adapter waterjet for around $60, depending on how many holes there are. I figure that a custom clutch is going to be around $400 (that's what it was for the Bonneville anyway), and I'd spend around $100 adapting my clutch line unless by chance the quick disconnect is the same.
So $1000 for all that, might have to get creative with the TIG to get the shifter, starter provision, and tail mount worked out. Plus the cost of the transmission.
