🔧 BUILD Boostie's Dust Collecting Unicorn.... 04 Cobra
Figured I would share with you guys my build so far. This car has brought me through hell and back and slowly getting it to my liking. Originally the car had a lot of weird and show type stuff like air ride and Tv's about everywhere you could look and was lacking in power. I have removed a LOT and changed+ added quite a bit. Wanted to build this car as a quick street car so performance wise I am pretty much done. Still need some suspension tweeking and minor details changed.
Quick rundown
04 Black Coupe
Power adder is a 2.3 Whipple
JLT High boost intake
RR pullies on all idlers/blower/accessories
Metco lower
Metco Alt pulley
RR Manual tensioner
Return fuel system
Division X fuel hat
Dual walbro pumps
80lb injectors
Magnafuel regulator
Exhaust
Bassani Mid length headers
Bassani Catted X Pipe
Basanni Cat Back exhaust
Cooling
Gords performance heat exchanger
Dual spal fans
Fluadyne radiator
Head Cooling mod
Suspension:
Kenny Brown Extreme Matrix subframe system
Steeda IRS subframe reinforcing bracket
Kenny brown brake cooling kit
Kenny Brown urethane IRS rear differential bushings
Steeda IRS urethane subframe bushings
Steeda urethane rear IRS control arm bushings
Maximum Motorsports caster camber plates
Maximum Motorsports front coil over kit
Maximum Motorsports tubular K-member
Powerslot rotors
Exterior mods:
18" True Forged Mach 5 wheels
Black Svt Trunk Badge
UPR stainless steel bumper inserts in polished finish
Carbon Fiber Stock Style Hood
Tinted Tail Lights
Clear Reflector Headlights
UPR Windshield wiper deletes
Hand polished IRS tails
30% tint
Painted fuel tank cover
Stainless tank straps
Interior:
Corbeau Forza Seats
Custom Rear seat Delete
Autometer lunar gauges
AEM wideband
SOS dual gauge pod
Autometer steering pod
Audio:
Alpine Headunit
Boston Acoustics speakers
JL amps and sub
Custom false wall for the sub and false floor for the amps
Trunk mat with "SVT" text
Bling:
P Fab polished Intercooler tank
Polished Coolant tank
Polished Power steering reservoir
Chrome Ford Racing Coil Covers
Powdercoated Gloss Black Valve covers
Powercoated Gloss Black Accessory Cover
Gloss black aluminum radiator shroud
Hood strut kit
Boostie
2,853
4,140
Been working my ass off getting the car ready for world of wheels again this year. Last minute things include
New battery
Stinger voltmeter terminals
Re-polished IRS tail pipes
Swap drag wheels for street wheels
5 point harness mounting
Hood and bumper are currently in the paint booth
Make a new false wall
Potentially add some temporary led ricer accent lighting lol
Sneak peek from detailing under the hood yesterday. Sometime this year I will more than likely be getting all the polished parts powdercoated for less bling and maintence
Boostie
2,853
4,140
Hood and bumper were finished today. The hood was new and the bumper had some holes from the previous owner put in from a grill that was on it. Got them mocked up right as the sun went down. Really pleased with the front end change up.
Boostie
2,853
4,140
Just freshened up the trans for the track season
26 spline input shaft
Fidanza billet flywheel
Promotion 750 clutch
Spec 3+ pressure plate
Billet retainer tube
HD Pilot bearing
HD Throw out bearing
Max Motorsports Clutch cable
ARP Hardware
Now to find the weak link in the car :jg:
Boostie
2,853
4,140
Ehrmagerd, so these fit without grinding?
Fronts needed a tinnnny spacer ~ 0.18" but unfortunately the rears being 15" require a grinder. I will say though 15x9 5.5 backspace have no interference with the brake caliper or banjo bolt like others do. It's a really tight fit with everything. I might order aftermarket bump steer parts as their toe links are smaller and will give more clearance in the rear
Those things don't need to be run with tires either. Read it on the internetz
No reason to have them mounted until I'm happy with the fitment
