April 2018 Truck/SUV stuff Craigslist & Ebay finds
89,635
https://www.ebay.com/itm/1129037130...d=142741079450&itm=112903713095&ul_noapp=true
89,635
https://indianapolis.craigslist.org/cto/6550382176.html
1967 M715/725
Cummins 5.9L turbo diesel 12 valve
New injector pump with upgraded throttle spring/fuel pin
New aluminum radiator
New power steering box
New starter
Power steering box reinforcemnt braces
NV4500 5 speed manual transmission
New hydraulic pump/reservoir for clutch
NP231 transfer case
1 ton axles
4 wheel disc brakes
New drive shaft u-joints
New Front axle u-joints
New kingpin bushings in front axle
New oil seals in front axle
Dew rubber bushings in all leaf springs
Heavy duty tie rod w/ heim joints
High mount tie rod kit
Front axle has manual hubs
Military tires
Hummer beadlock rims with internal run flats
Hard top roof
Rhino lined outside
Removeable doors, roof, and cab rear
Working blackout driving lights
Heater
Fan
LED light bar
12v electrical system
Troop seats with canvas bows
Extra set of bed stake sides
Toolbox for bed
Front and rear receiver hitches
Military antenna mount
Jerry Can mounts
Trailer wiring harness with brake controller
89,635
intertasting
https://www.ebay.com/itm/2731309784...d=173250029367&itm=273130978429&ul_noapp=true
2005 GMC Sierra, 4x4, 236,968 on body.
5.7 LS1 100,000 miles, 520HP at Crank.
Engine: Built by Vengence Racing Atlanta, Ga. fast Intake, trick flow heads. Magic Stick 3 Camshaft from Texas Speed. Upgraded rocker arms, oil pump and chain. All installed 4 years ago.
Transmission: Re-manufactured, has around 500 miles since installed. Warranty 3yrs/50,000 miles, 12/2017, have paper work.
Suspension: 6” Rough County, 3” body, 2” torsion keys.
Wheels: 22x14 XD; Tires: 38/15.50/22 like new.
Front End: New axles, ball joints, tie rods.
Rear End: New bearings, seals and factory gears.
Painted Jan. 2016
Leather interior, spray in bed liner, HD mirrors, shaved door handles, Hidden receiver hitch under flip up plate.
Stereo: Kenwood head, Alpine type R components, Alpine 450 watts, 4 channel Amp, 1000 watt Alpine Mono Amp, 2 Sundown Audio 12’s.
Runs great, clean, owned for over a 1yr, Clean title in hand.
Vehicle advertised locally for sale. Reserve the right to end action early.
Cash, Cashiers Check that must be verified.
I’ve put less than 500 miles since purchase 12/2016. Parked inside majority of the time.
No trade please. No Reserve.
