Well that sucks. Any idea where it is squeaking from? The entire axle isn't really that complicated. The axle as noted before is just a limited slip and thus needs the friction modifier for the clutches same as a non-quadrasteer lsd. The inner and outer tie rods in addition to the upper and lower ball joints are available from rareparts.com but aren't cheap. Other than that you have the motor and sensor which I wouldn't think would squeak and the rack which has a large spring, some seals and plastic boots. Can you get under there and take a video to pinpoint it?
