2001 GTP Coupe
Well the time has came. After all the time and money spent it's time to move on. I'm officially selling my GTP. Figured I would post on here first. It has the L26 top swop. GenV blower, zzp heads, full size intercooler, zzp race trans. Pace setter headers, 80 lbs injectors, E85 fuel pump, currently running on pump gas. Last Dyno on pump gas was 309. When was on E85 was 360.
Asking 3,000
boostedguy05
not well known
34,281
25,744
Asking 3,000
It has an XPZ cam. You cannot read.
in Panda's defence, he mentions nothing of the cam in the post.
1quick
26,615
24,247
coal city
OK, my mistake. I figured a "ZZP 2.0 Tune" was canned.
Doesn't matter - same question. Can you view what they did with the powertuner?
Also, what do they do when swapping from gasoline to E85? Pull timing or pulley up?
On e85 they add fuel and timing and normally pulley down, your better off adding boost over timing in my experience
b4black
before black
Jun 6, 2008
1,331
542
Oswego
I know what a powertuner is and does. I was just wondering if you looked at what they did. Not that they 'retuned' it, but what exactly they did. I guessing you wanted to go back and forth between gasoline and E85. Besides swapping fuel, you adjust the injector skew and then pull/add X° or pulley up/down X" or both.
I know what can be done (and I know what I do), just wondering what the "professionals" do.
Xtant12
3,318
67
The car is in island lake IL
