Emerballs' Army Trailer Build
EmersonHart13
UNSUBSCRIBE
Posts
51,978
:jg: Well actually it didn't just appear there... I had to drive all day and get it:
I guess [MENTION=19]Yaj Yak[/MENTION] and I were having the same sort of idea at the same time and he beat me to the punch and we both took different routes...:werd: Thanks to [MENTION=2449]ilikemtb999[/MENTION] for the knowledge assist.:fy:
It is an M116A3 with an A101A2 bed on it for those that know their lingo.
Harbor Master
Posts
106,975
omg so amazing.
ps my indel fridge has been at 33* for 3 days in my truck now.
10sec
Posts
24,971
Awesome thread is AWESOME.
EmersonHart13
EmersonHart13
UNSUBSCRIBE
Posts
51,978
EmersonHart13
EmersonHart13
UNSUBSCRIBE
Posts
51,978
So what is it and what do you do with it?
Serious answer. Like [MENTION=19]Yaj Yak[/MENTION] 's thread about his new truck, adventure camping. We are going to start out light and just start hitting the national parks. We were planning a cruise in the Mediterranean next year but we shit canned that when I found out I will be job hunting at the end of the year.
The trailer will be getting a new axles with 32" tires which will lower it a good amount as the current tires are 37s. (tires, axle, and surge for sale down the road) The new axle will most likely be electric brakes instead of surge. Getting rid of all that will take several hundred pounds off as well. I am selling the canopy, bows and sides and they are not part of my build.
Then build a rack, which I borrowed this from a guy who I am stealing a lot ideas from: (Thanks Expedition Portal)
So in the end it will be something less beastly: :noes:
And behind the almighty FJ Cruiser :pedobear:
Basically the trailer stays packed and ready to go.
Yea but how many acres..?
Posts
59,824
But I was gay when I bought mine though right?
Posts
59,824
And a more than capable truck of pulling it
Posts
59,824
What does that have anything to do with it? It had enertia brakes. Lol
Bob Hope
Formerly Alive
Posts
75,590
Then it must of been modified because they were made with air over hydraulic and not surge.
Regardless, stfu
Harbor Master
Posts
106,975
this is awesome. you get an FJ?
also, what RTT you going with? I'm flip/floppin' between CVT & Tepui currently...
Good to know. We aren't going fridge right out of the box. We did invest in a fancy cooler already though. That will be on the upgrade list if we see a need.
https://www.igloocoolers.com/sportsman-70
Thanks
just so you know, if you do pull the trigger, i got mine through TruckFridge.com - Quality true 12 volt DC compressor refrigeration with freezer - Georgetown, KY Exit 129 next to Piolt Truck Center - many models to choose from.
https://www.facebook.com/TruckFridgeKY/?fref=ts
they were running a 25% off sale, and free shipping deal. I got a TB51, it's sweet. i like it.
This thread makes me smile lots
me tooooo
Harbor Master
Posts
106,975
also, what will this weigh all said and done?
EmersonHart13
EmersonHart13
UNSUBSCRIBE
Posts
51,978
M105 data plate for reference:
Significantly heavier than what I purchased and not applicable to this discussion.
I KNEW IT WOOD
me tooooo
I don't have an FJ, my brother used to. Still have Montero Sport in second photo.
As far as RTT I have only done preliminary research but being a tall lanky bastard I have been looking at the oversize tents designed for 3-4 people as they typically have room for my tall ass. The wife has also informed than an annex is required as well as an awning.
I'll check ou that fridge.
So right now it weighs approximately 1500lbs plus. Since this trailer is a mutt I cannot be for sure but look at the data plates I attached. My Montero like most mid sized SUVs can tow 5k lbs though since it is older it definitely doesn't like towing all 5k and it is a coil rear. I added helper bags a long time ago so it took the weight like a champ. I also recently leveled it and even with the trailer it stayed pretty level.
I pulled it home with the surge brakes disabled as they are touchy and at 1500 lbs I had no problems stopping it. I think the surge shock is worn out and causes the brakes too actuate too easily.
Losing the 37s, surge hardware, and heavy duty axle I am expecting to lose around 500 based on what I read. Really that doesn't matter as I am obviously going to add stuff back on. The plan is to be under 2000 lbs loaded up with a max of 2500. If I am more than 2500 lbs I have too much stuff or I need a bigger tow rig.
There is household debate about that right now but as I mentioned my job is going away so that isn't happening now.
Harbor Master
Posts
106,975
im looking at similar size tents, for similar reasons to you, the tepui one i like... and i love the idea of the annex too, definitely necessary... awning is a go also.
im pumped you're doing this :rofl: this is what im planning on doing with my truck, but youll definitely have more offroad capability.
