GTPpower
6,351
9,752
Nebraska
Pulled the flexplate and rear cover off to regasket it.
New cam
New LS7 lifters
Set timing straight up.
Lifters in.
Rockers on.
Measured my pushrods last night. This is at zero lash, so I can either order them .050" longer or turn the adjustment down another round.
The pushrods that came with the cam are nowhere near long enough. I have a set that came with the heads, so I'll have to measure those and see if they are close.
I also need to get the crank sprocket chamfered now that pushrods are measured.
Xtant12
3,318
67
I'm not trying to steal your glory, but I think we have a very similar built so far! I'm excited to see your outcome because you used the 04 block and I used a 06. We also have the same cam and I think springs. What size injectors did you go with? I'm very excited to see your build!
GTPpower
6,351
9,752
Nebraska
Hold up....are you running 90# springs on a xpz?
