GTPpower
6,351
9,752
Nebraska
All put back together. Completely rebuilt with a few new abnormal parts, a new valve body, and a few updates and tricks for better performance, I've probably got $500 into it. Pretty easy and cheap to do by yourself.
I'm about half done with the hydroboost swap. Figured out how to make the stock pressure line work. Now, the pressure line to the rack needs to be shortened, then plumb up a drain and I'll have to make an adapter for the brake pedal.
GTPpower
6,351
9,752
Nebraska
Found the parts to fix the coilovers
Installed them along with new axles. One axle boot was leaking quite a bit.
I wasn't very happy with the oil pressure this engine had, so I decided to shim the valve while I had he engine out.
Here you can see why I had a boost leak. This is as far as the bypass would close.
Welded in a bung for a iat sensor that's accurate.
And this one didn't go as well....
Cut it out and tried again....same thing....
Finally got it on the 3rd try.
And the engine is back in.
v6buicks
6,369
15,814
Franklin, IN
Jon
I'm not an expert by any means, but I'm not sure how new you are to this. Forgive me if this all seems obvious.
Are you trying to weld that all in one pass? With a small part like that and needing to weld around the whole thing, I would think that your issue would be resolved by lifting almost completely off the pedal by the end or just doing it in two passes with a long break in between. You have to start gradually letting off the pedal as soon as you get your pool because the heat dissipation we love about aluminum is a big part of what makes welding it a massive pain! Even if you are running a long straight bead, the whole piece is going to be horribly heat soaked by the end of a pass. It's only going to be worse if you're welding around a small bung like that. That's just my $0.02. I'm not sure how fancy your machine is either, so you might have settings to deal with this sort of thing.
