GTPpower
6,351
9,752
Nebraska
Video from the Dyno day on Sunday. Power was pretty weak, but thanks to all the local friends that were there, I had lots of eyes to help me watch it. We found out the bypass is not closing. I'm not sure how it's even making boost, but at least now I know the problem why it's not making the power it should. So, now I'm going to weld that shut, install a bov, and I'm about 97% sure that I'm gonna to fix the transmission myself.
10sec
25,951
5,836
I would imagine the drive losses would be insane if there was a way to spin it that fast. I also don't think he was seriously asking. I think the sound of your setup is so unique it'll have people thinking you're running a super small pulley. They certainly won't take the time to read anything you put in the description, TCG and the world, does not read.
Reactions: Yaj Yak
Mr_Roboto
25,920
31,098
I would do it as 2.70/1.05 which is around 2.58". I may be off on this but I think the ratio should be simple being based on linear distances. I would go up on driven pulley size vs down on blower snout pulley size if plausible just due to the belt area up top being small.
Based on a 6.94 stock crank pulley diameter*1.05 divided by 2.7 I get a ratio of ~2.7:1. How odd it worked out evenly like that. You'd be looking at what 16.2K if you were spinning the engine up to 6 grand. Off the sheet if I remember right.
GTPpower
6,351
9,752
Nebraska
Ah haha. Ok that makes sense.
Reactions: Rent Free
GTPpower
6,351
9,752
Nebraska
Yeah, it's easy to figure blower rpm.
I would like to go bigger on the crank, but the ati 10% balancer is like $600.
I found someone selling one with a 28% od pulley, which is around 10". So I could run a big upper and not worry much about belt slip, but I'm not sure that would even clear my subframe.
