ZZP Power Drop Harness??
Harbor Master
from the reviews...
ordered a drop to clean up the spaghetti i had under the dash. very simple install. wire in the lights to your gauges and THEN run a switched wire to the pink wire and ground to the black. thats it ! AWESOME INSTALL. very clean.
orange wire - constant power
pink - swithed
black- ground...
A must for anyone who wants plug and play power supplies and grounds for their vehicle. As a ASE Master Technician, I highly advise this rather than tapping into existing factory wires as well as taking the guess work out of installs....
pretty nifty lil dealio
shaferz
slaps a ho
Central IL
shrug. screw the harness. If you can strip wire and solder, then dont blow the money on the harness.
Handsome Jesus
A V6? What a ripoff...
Carpentersville, IL
if you pull out that wierd fiber stuff under the dash (held in by those plastic tree things) there is an empty harness in there that has a large white tag on it telling what each wire is.
Power drop harness is kinda nice. I have one...
Fish
From the mean streets....
Chiraq
All I get is this when I click on it.
"Sorry. There was some problem with the data."
smug
Cedar Lake, IN
behine the glove box and fuse box on the pass side......
the switched wire the awesome for running an ic pump
02BlueGT
No Fucks Have Been Given
Now apearing in Hanover Park
Like Double D said, under the pass dash, if you cant see it from the bottom, Squeeze the sides of the Glove box in so it sill swing out past open, and the harness is plainly visible behind it
DanJoy
I use the exact same thing 1998gtgp posted. Available at Autozone so check it out next time you are there.
