ZZP HID troubleshoot
99blkgt
Active member
Went out after work today to install my ZZP HID kit...Hooked the wires up to the appropriate places and nothing. Anyone know what the problem might be? I cant stand my silverstars anymore.
99blkgt
Active member
You tryed to see if your getting power at the bulb socket?
[/b]
Im not sure exactly what you mean by that....My old bulbs worked fine before and when i reinstalled them after attempting to install the HID.
UR LOSN
Pirate Sloth!
Rockford
connect the blue plug that comes out of the ballast to the headlight plug. MAKE SURE the plugs on the back of the hid bulbs are "clipped in" and locked tight together. before mounting the ballasts...check to se if they work. if they dont switch ballasts and see if the other one works. also/....check the meezly 7.5amp fuses....if they are shot replace with something like a 10-15. I blew my 10amps..and have 15's in them right now..with no problem.
if they still dont work....your SOL.
