After looking at the logs and having my tuner take a look, we believe the slow time/low mph is simply because of the TCM stepping in and telling the car to short shift. On the 1-2 it shifts at 5800, 1k rpm lower than where it should. And every gear after that it shifts at 6300. I didnt even make peak HP until 6400 and it carried to 6800 when we dynoed it.
So long story short looks like the TCM/trans tune is in order. initially my tuner said I "probably" wouldnt need it at this power level, but it looks like we are hitting the tq table limits in the TCM and its not happy.
One thing about these ZL1s, they are so well tuned from the factory to not only run the stock number, but protect themselves, there are basically no mods you can do without a normal tune that will do anything to make more power. Once you run to the limits of the PCM tuning, then you have to contend with the TCM's tq management parameters. The TCM can command the shift and also to close the throttle. We are not there yet where its closing the throttle, but its killing the power by short shifting. And on top of that its dropping me well below peak tq into the next gear as a byproduct. Look at the RPM it shifts at in the log on the 1-2.
