Soooo just wondering your guys opinions on an engine and tranny setup.
1975 351 windsor
trw L2456 pistons 10.0: 1
comp cams 35-330-3 cam kit
(Cam Style:Hydraulic flat tappet
Basic Operating RPM Range:2,500-6,500
Intake Duration at 050 inch Lift:244
Exhaust Duration at 050 inch Lift:244
Duration at 050 inch Lift:244 int./244 exh.
Advertised Intake Duration:292
Advertised Exhaust Duration:292
Advertised Duration:292 int./292 exh.
Intake Valve Lift with Factory Rocker Arm Ratio:0.518 in.
Exhaust Valve Lift with Factory Rocker Arm Ratio:0.518 in.
Valve Lift with Factory Rocker Arm Ratio:0.518 int./0.518 exh.)
heads redone with new springs and seals and valve job
ford motor sport oil pan and dip stick
melling high volume high pres. oil pump. arp oil pump drive shaft.
1975 c-4 alto red racing clutches
alto red race band for 2nd and reverse transgo shift kit
tci 3000 stall converter
Annnnddddd would these be nice for said engine? Edelbrock SB Ford Cylinder Heads
1975 351 windsor
