yet another issue!!
GLIKENNY
Hooligan
Oct 7, 2008
815
4
Darien, Illinois
Kenny
a couple months ago Sinister DD replaced my LIM gaskets, coolant flush, changed oil, and put on poly motor mounts. Since then there has been a vibration that is driving me crazy. I have replaced both front wheel hubs, calipers, rotors, checked all things suspension to make sure nothing is loose and everything is spot on. what can be the cause of this problem?? im stumped and about ready to give up with this car and sell it. Can the poly mounts be the culprit? do i need to replace the axles?
Sinister Drag Designs
SinisterDragDesigns.com
Aug 3, 2007
4,876
Chicago, IL
The polys will add a little vibration as I told you, but sounds like there could be another issue if its real bad. Give us a call or stop in on Sat.
GLIKENNY
Hooligan
Oct 7, 2008
815
4
Darien, Illinois
Kenny
Did you have poly mounts before? How bad does it vibrate? Shake the car vibrate? or massage your hands vibrate?
no, i had stock mounts before. its not shake the car bad. its more of an annoyance vibration. there is a kinda loud humming vibration is about the best way to describe it. its not vibrating parts off the car bad.
As for my tires, I have slightly more than 1/8 tread left. I had an alignment done about 3 or 4 months ago.
As i said, it seems to be more pronounced while turning and at higher speeds.
it can be heard more inside the car then outside the car.
Ron Vogel
5,174
4,273
Ron Vogel
Yeah, it's a tough call...and I'm facing a similar if not the same issue. I am replacing my axles though. I believe mine is on the driver's side, and also not leaking...however, it pulls out farther than it should and only noticed it when I rebuilt my suspension. Not a lot of components down there, and I have hubs with less than 5K miles, new ball joints, tie-rod ends, bushings, and a fresh alignment.
GLIKENNY
Hooligan
Oct 7, 2008
815
4
Darien, Illinois
Kenny
The hub bearing i have are less than 1K miles. that was my first repair since i thought that was the cause, so i guess ill just swap some axles now. Where can i pick up a reliable set? Napa? ZZP? or other?
MIKES3
3,835
21
Algonquin, Illinois
