i basically wrote the thread hoping for your posts. i tagged you even!
so to combat my power do you think i could turn heat on in my garage, warm the thing up and make it further?
Do they sell battery heaters or a sleeve that will wrap around the battery?
scrolled through and nothing about giving her hell out in this snow??? holy Tokyo drift
I have seen sleeves for batteries. I think they are mostly in cold climate areas where it’s sub zero weather.
However most of this are made for the traditional 12 or 6v battery sizes.
it's cold
the batteries are all group 31 12v batteries. there are 8 of them.
lithium was an OE option, but it was like a metric fuckton more money, and apparently you need a different onboard charger with lithium? dunnno.
Those SLA batteries are likely Deep Cycle marine style batteries. So you are probably looking at $1200+ for replacement batteries of a similar performance curve. Electric vehicles are way more demanding on the constant and surge draw than a starter is.
Lithium is more yes, but it likely has way more punch and acceleration even if the top speed isn't higher. Also longer lasting as well I'll bet.
EDIT: Just looked up the battery packs. The SLA batteries are 9.4KWh total, while the Lithiums are 21kwh. So that would explain the price difference. Twice the battery capacity, and probably 4 to 5x the maximum continuous current draw. That explains the price differences a bit.
