WTT: Clean 92 Notch Ladder Race for street car
wrenchlist
WrenchList.com
$10K firm cash or also interested in trade for street cars: 2001-2003 GT or 96-98 Cobra of equivelant value. Automatics desired. Naperville, IL area.
1992 Red Coupe, Totally rust free (body seams are spotless) This was a sunny/dry weather only car. Nice clean black interior car with perfect original carpet. Body has 97K Miles. Everything works (wipers, lights, door dinger, gauges, AM/FM/CASS is there but not connected (I was going to replace radio at some point)
Chassis: (Done by Ed’s in Aurora in 9/06)
Chris Alston Adjustable Ladder Bar/Adj Coilovers
8 Pt Bar, prof. epoxy black, padded
Frame connected, tabbed to and through floor, tied to cage
New 06 5 Point Harness RCI Belts (Red)
Professional Minitubs to frame (added 3+ inches)
8.8 with 31 spline Moser Axles / Spool
Fresh 3.73 Motorsport Gear
T/A Stud Kit and Girdle
Aerospace Rears, 5 Bolt pattern
Aerospace Fronts, 5 Bolt Pattern
Aerospace Braided Front Lines
Racecraft 2” Drop Spindles
Aerospace Manual Master Cylinder
Moroso Line Lock
Flaming River Manual Rack
90/10 Lakewoods
Moroso Trick Frotn Springs
FMS Caster/Camber Plates
Weld Draglite 15x10 with 28x10 MT slicks, Tubes, 16 Rim Screws each wheel
Weld Draglite 15x3.5 with 165x15’s
McGard Lugs
Also 5 bolt 2001 GT wheels with street tires
Battery in Trunk, New Red Top Optima, Aluminum Box
Rear Cutoff switch through rear license plate
Engine/Power:
Engine was professionally redone by previous owner in 1998
306, .030 TRW Forged Pistons, Rings Bearings 10/10 crank
New Ford Motorsport valves/springs/cam ( I don’t know the grind)
Recon Stock Rods
BBK Full length headers
New OEM Bosch Oxy Sensors
Stock/Upper Lower Intake modified for 75mm BBK T-Body and EGR, brand new
Underdrive Lower Pulley ( I also have a new aluminum March spare)
Aeromotive A1000 Complete System (Tank, pump, filters, rails and regulator)
Powermaster Alternator 140 amp
CSI Electric Water Pump
Lincoln Elec. Fan (4200 CFM)
New Radiator and hoses
A/C equipment removed underhood (before I had the car)
T-5 with 10K mile clutch
Interior/Body:
Car was repainted in Cobra Red in 02, paint is nearly perfect and looks totally factory. Great gloss, very well done. Car was disassembled correctly as you can’t find lines. Window Moulding is really nice shape.
Rear window lightly tinted.
2” Inch cowl Glass Hood with pins
Headlights and taillights are really nice. Emblems too etc.
Interior is really nice, Rear seat needs to be fit to the tubs
New water pump, electric fuel and oil pressure gauge
http://www.wrenchlist.com/content.php?content=92MustangLX
email [email protected] to chat or for pictures and details.
