WTF, pully bent using puller
BigJermGTP
Montgomery
Ok Im just wondering if anyones experienced this before. I got a 3.4 pully and the puller. I have the puller set up exactly the way the instructions are showing me, and the more I start turning the nut on the puller to take off the pully, the removal plate is digging into the stock pully. Now granted im not going to use the stock one anymore but im freaking out cause i think im doing it wrong. I know for a fact the puller was on there corectly, because my bro was helping me out and hes an ase certified mech. Needless to say i got the 3.4 on just fine and Im really pleased with the performance of my car now. If anyone can shed some light on this that would really help, thanks
98 TGP TOY
Morton, IL
Stock pulleys are weak. I have seen a couple pulled properly, and then ended up bent. Its the pullers (tool, not person) fault, i beleive.
alexgtp
:lolsign:
LIke this!!
HAving done well over 150 pulley's. This has only happened to me once. And this was on an ASE pulley (which are weaker than hell).
Did you remember to use slow even pressure while doing this? Also never work on a HOT motor. Heat will cause the snout shaft to expand thus making the pulley harder to come off. Working on a stone cold snout is the preferred way.
Glad everything came out OK.
It sucks when you break a seal on the snout.. or strip the M8 stud or bent the pulley like a taco!!
Royalgtp
I cracked the pullers main stud.....
WHich I hear is imposible to do because the way it is made...
Looks like all those workouts are paying off... B)
rjaz gtp
Naperville
So Alex is that pulley considered a 3.7 and a 1/2 then?
That has to be the worse pulley I have ever seen on a car!
Did that things actually come off just using the puller then?
Royalgtp
Some of them snap off and leave the whole screw area left over......
I
itlnrob
Originally posted by alexgtp@Feb 8 2005, 07:39 AM
:lolsign:
LIke this!!
[snapback]70709[/snapback]​
how much do u want to install a pulley?
