Poor form for DL can seriously fuck your back up. Not sure how old you are, but I'm 44 and very rarely DL anymore. Risk/reward factor just isnt there imo. I might DL once a month and keep it below 275lbs. 4-5yrs ago I was DL 495lbs with wrist straps and 405lbs without them.my form is shitty and i am weak and just trying to do deadlifts yesterday, and not my max weight, i tweaked something in my back. no muay thai today hopefully normal in the next few days though. getting old/being body stupid kind of sucks
I use this if I am doing a long run or bike.Question, do you guys use anything for pre-workout fuel / energy booster? Or have you in the past that you could recommend?
How is your caffeine tolerance? Might want to use a non stim pre workout if tolerance isnt high.Question, do you guys use anything for pre-workout fuel / energy booster? Or have you in the past that you could recommend?
I think itās okay? I donāt drink coffee or soda, so this would be the only intake of caffeine.How is your caffeine tolerance? Might want to use a non stim pre workout if tolerance isnt high.
I have a high tolerance and this has been my go to for a while now
Pre JYM High-Performance Pre-Workout
Revolutionary pre-workout formula that goes beyond basics to deliver short- and long-term support for your performance and results*www.jymsupplementscience.com
Pretty fucking impressive manDid a mock meet the other day. Squatted 455 easily, probably another 20+ in me, 330 bench paused, and a 525 deadlift. Goal by the end of the year is to hit a 500 squat, 350 bench, and a 550 deadlift.
Don't do this again. Avoid compound lifts (at any weight) until you fully understand and can execute proper form. hypertrophycoach on IG can get your mindset right if you watch his vids, but in person it normally takes a GOOD personal trainer to teach you how to activate the right muscles and avoid hurting the muscles/joints that need to be protected. Good personal trainers are few and far betweenmy form is shitty and i am weak and just trying to do deadlifts yesterday, and not my max weight, i tweaked something in my back. no muay thai today hopefully normal in the next few days though. getting old/being body stupid kind of sucks
Pick a movement/exercise, watch a bunch of YT videos to learn how to perfect it, then focus on that your next time at the gym. For other exercises, stick to dummy-proof stuff and light weight
Age, HT and weight?
Trap bar is definitely better for your back, so is sumo as long as your legs are wide enough apart. If you feet aren't any wider than a conventional dead, and you put your arms between them, you're gonna hurt yourself. It's just important to note that very few people understand how to do deadlifts with near-perfect (safe) form, and even fewer can actually execute it. Whether it's from ignorance, inflexibility (this is common and not easily fixed), or "other". Core needs to be locked, breathe from your belly, hinge at the hips, hamstrings/hips/glutes can't be overextended because that'll round out your lower back (this is where flexibility comes in), lats need to be braced, etcthere's actually a PT in my muay thai class and i did some with her last week and will likely again saturday and it definitely helps having her there to critique my form and give me cues and so on. something she had me try which i ended up liking a lot is having my arms between my knees/narrow grip. so i suppose it is a sumo deadlift now? my gym also has a trap bar which seems to have some plusses and minuses but one of the plusses seems like it can be more forgiving on form.
WOW, big boy, no homo!30, Little under 6 7, 257. Natural as well.
I always loved deadlifts but had to stop doing them because I don't have the hamstring or hip mobility to properly execute them :-( I did not learn this until DL'ing started causing back pain
hmm thanks on the feet - i mean my grip is inside but my feet were definitely not wide, pulling up an alan thrull video now on sumo. what do you now instead of DL?
I was having lower back issues especially when I would dead lift or squat heavy. I started finishing off with an exercise where you bend forward and on an angled bench then lift your upper half by your lower back muscles. I wish I knew the actual name for the bench but it's usually at a 45 degree angle with pads for your thighs and it holds the back of your heels in. I do that with a 10-25 lbs. plate. That plus strengthening my core helped a ton.Can anyone chime in as to what would be a good set of simple exercises/lifts that I could possibly do at home with every day items to strengthen my lower back and to support my SI joints? Or maybe ones that I could do once I get back in to the gym?
