Wiring for Additional Fuel Pumps
Zack
4 Doors 4 Life
Mar 21, 2004
6,297
20
NW Indiana
I had mentioned this in a thread long ago but I fear it was overlooked.
I was prompted to make this topic based on seeing Blown3.8's work on MM.net. (passing wires through a bulkhead then filling with epoxy.)
Im not knocking his work by any means, I just know epoxy can crack over time and can lead to leaks.
I use this product on my own Marauder and it works great!
Racetronix - Universal Bulkhead Wiring System, 4-Way
You drill a small hole, insert the fitting and its held on by a spring clip on the other side. The o-ring is resistant to gas and oil. (and E85)
Just thought id share. :wavey:
1quick
26,608
24,185
coal city
Yep. Mine are dual Walbro 340's in a modified stock pump hat in-tank. Some of us are making enough power where we need the extra flow; but don't want to do a large external pump like an Aeromotive, Weldon, etc.
so do your 2 pumps y together in the tank to one fuel line? I thought about doing multiple pumps for e85 use since I was told that a 255 is only good for mid 400whp on e85 but i ended up finding that the aromotive in tank 340 fit so i went with that for now
rocket5979
Gearhead
Nov 15, 2005
6,576
Round Lake, IL
Yes, they Y together to a larger single fuel line, and exit the pump hat through a -8AN bulkhead fitting. The FPR return line attaches to what used to be the stock feed line. Still retains the factory siphon jet pump system too so there are no issues with the gas gauge reading 1/2 full but sucking the passenger side of the tank dry while the drivers side remains full. My whole approach to this car is to be a fast street car while getting good gas mileage and not sacrificing any creature comforts or conveniences. I was going to go with dual Walbro 400's but I already had these 255's left over from a previous project and they will support the power I plan to make for the time being.
I agree that there just isn't any reason to resort to using epoxy or anything else to try to reseal the tank after drilling or cutting holes in it. There are so many methods out there that are inexpensive, seal the tank as well as OEM, and are fuel resistant to resort to halfassing it. I seen one guy who stuck a Bosch 044 pump in his by holesawing through the top of his stock pump hat and then just JB welded the top of the pump in place. lol. Terrible application and the pump was physically WAY too large for the area it was stuck in that it not only stuck out of the tank but also out of the sheet metal under the rear seat too.
massacre
161
I always admired how you modified the hat/wiring to run return-style.
Thanks for posting!
My car was already return-style from the factory so I didn't have to modify much.
I'm still impressed that modern cars run electric wires inside of a tank full of gasoline/vapors. In the old days that never would have happened lol.
NATEHAWKMM
Mar 12, 2012
14
Im the car you all speak of....We did not any in case do a hack job....The wires pass thru the bulk head fitting....The fitting has a ring that seals it to the fuel hat. But to be honest I did end up after a few weeks with a leak and im sure the epoxy did crack. I'll order one of these asap for a leak proof fit. I didnt know about this harness b/c I would have ordered it in a heart beat. We just didnt have any other ideas at the time. Thanks for posting this link again Zack, I appreciate it....
