window problems...
zeez gtp
Bolingbrook
well, the lineing or whatever you call it that holds the window on the outside is starting to deteriate. condensation gets in my car a little bit and it fogs up real easy. when i roll my window down and roll it back up, it falls out of alignment, i didn't realize it once and i thought the window was going to fall out when i was driving. where can i go and get this fixed at. is this more of a body shop repair than just a mechanic shop. i just need that stripping that goes up the door to hold the window tight and sealed. thanks
z
