Will installing HID's void warranty?
DanJ
33,567
16,928
If you were that worried about it you could always swap them out before taking it in. Isn't there a law that covers this? Something about unless a failure is a direct result of the modification they still have to honor the warranty? So unless the HIDs fried your headlight harness or melted the housings they would have to still cover other mechanical issues.
27,986
Check into those to make sure they have "real" high beams. The HIDs I bought years ago said they had high beams but, instead, had very dim, useless lights they somehow called high beams. I thought you need two ballasts per light for real high beams but that may have changed? It's been a while since I installed mine.
Smokinhot
3-man rules!!!!
Jul 4, 2007
14,060
1,836
Lansing, IL
IM me if you wanna know more ;)
I will, it's all integrated into the one bulb. So far I've heard good things about the setup and they had a DIY setup vid and it seems easy as hell.
I guess, I'll have to ask about the relay kit.
You guys are going to love the HIDs!! The kit is sick because it integrates High beam function into the bulb. Looks great on my se. Just make sure you get the Relay kit unless you want to do some modifications, since the base kit doesnt come with the right connectors to the 3 pin HL connection.
:rofl: I am clueless on HID's. They were a sponsor on a Hyundai forum, and everything seemed legit and easy enough :dunno:
I'll look into that place
27,986
The best kits are plug and play where the kit plugs directly into your headlight plug. Then you find somewhere to mount the ballasts and done. On my Cobra, I took off the radiator cover and found some nice niches on the side of the radiator for the ballasts. Screwed them into existing holes and you couldn't see the install once I put the cover back on.
85,459
45,569
JK
They're all plug and play but I would not plug them directly into the stock wiring. Using a fused wiring harness that plugs into stock harness is best.
