Wild 4th Gen F-Body Build - IRS, dry sump turbo V6, mini tubs
Bru
Wow. Amazing fabrication work from this build. Looks like all of it is garage built, too. I spent a half hour reading this thread and he's documenting the build very thoroughly.
Wheel alignment for 4th gen IRS swap - LS1TECH
GM 3.5l 60 degree v6
*Custom Weisco forged pistons $550
*Comp "street/strip" turbo cam $350
*Eagle 327 H-beam rods $450
*ARP 2000 rod-bolts $60
*Childs&Alberts sbc main bearings (Bought two sets for upper bearings) $100
*Coated cam bearings $80
*Manley LS stainless valves w/ Dodge 318 valve-stems $150
*Manley valve keepers and retainers $90
*Head machining and assembly, valve-job and porting $450
*NTR Dry-sump oil-pump, cog-wheel and mandrel $500
*Fidanza aluminum Flywheel $250
*custom oil tank (Aluminum was freebie... welded it myself)
*Crankshaft knife-edging & machining, Custom trigger ring install. Con-rod modification and machining, Block prep and machining, rotation Balance, casting flash removal, Piston coating, block coatings, flywheel balance (etc) $3000
Boost goodies
*Comp Turbo CT3682 "Billet-wheel" Compressor w/ 1.05 AR T3 & P-trim turbine and water-cooled cast aluminum housing $1350
*Dual MV-R watercooled wastegates $500
*Synchronic BOV $250
*Turbo headers (Home made) about $400 worth of 304 stainless mandrel bends, clamps and expansion joints
*Cheap turbo blanket (probably Chinese made) $75
*Frozenboost performance Heat exchanger, w-2-air intercooler and water pump (used) $200
Engine management
*MS3-pro ECU + harness $1200
*6' Delphi 850cc (85lbs) Low-impedence, Fuel injectors $370
*PLX wideband O2 controller $200
*AEM Peak-n-hold driver $250 (ebay)
*misc harness stuff $150
Transmission, Brakes and Suspension
*92 ZR1, dana44 complete rear suspension $1500
*UMI front, Road-race, lower control arms with roto-joints $600 something
*UMI Road-race LS1 K-members $500 something
*BMR trans-cross member (freebie)
*Banski racing fully adjustable toe, camber and trailing arms $1200
*TKO600GM 5-speed tranny $1800
*Lakewood Bellhousing (metric) $100
*Home-made shifter handle (Truck-chrome) $100
*Tremec shifter-ball $40
*CTS-V 6-pot calipers $750
*2010 Camaro SS 2-part, "aluminum hat" brake rotors $500 (got lucky as hell)
2005 ZO6 ABS brake-module $650
misc junk $300
Body control, wheels tires and whatever else comes to mind
*C5 magnesium wheels and "cheapy" tires with meat on em. $800
*ISIS can control system $1500
*Vis Carbonfiber hood (Thats got baked in the [email protected]#king sun while I was away) $750
*Woodward collapsing steer column, detachable hub, Momo steer-wheel $725
*Homemade dash with equess-gauges $250 and some TLC
*Adhesive aluminized reflective heat barrier $150
RICH17
Dr. Pussy Slayer, MD
The 007
That's nuts but 3500 motor? Why not make some real power with a LSx?
And did C4ZR1's really have inverted coilovers like that?
Typhoon
I dont know what year that car is but 93-94 v6 cars came with a 3.4. The 3.8 came in 95. I "think" the 3.5 is 60* V6 like the 2.8, 3.1, 3.4, etc... The only reason I can think of is that is what the car had in it from the start?
Slow Buick
eat ass drive fast
Maybe he didn't wanna do the 3.9, pretty sure that's the same architecture
Neat build for sure
ilikemtb999
I eat dirt
Denver, CO
That's ballin minus the engine. What a waste of a kick ass chassis build.
Handsome Jesus
A V6? What a ripoff...
Carpentersville, IL
It does seem like a bit of a mish-mosh of desires though. What exactly is it intended to do? Big thing is manual and turbo... and of course other things too.
RICH17
The 007
Yea the 2.8 tp 3.9 V6 is basically the same block through all the years. Just seems like a crappy motor to put with that bad ass chassis like Jesus said
guspech750
Guspech Superdriller
North Aurora
Wow! Just wow!
I read the entire thread and envied every step of the way. I definitely saved that thread on my phone to continues living his dream.
bikrboy128
Some say.....
Wheaton
so much great work....puts piece of shit engine in it. still an amazing build
RICH17
The 007
Finaally read through the whole thread. What a great build. And he's doing it all by trial and error. Makes me want to get out and build something
Thirdgen89GTA
Buffalo Grove
3.9L had excellent flowing heads. Perfect for Boost. Excellent torque at idle and the power band was very flat to red line. Basically you were never in the wrong gear when I owned my 06' G6 GTP.
Still, it was only 240hp, GM cammed it a little soft in my opinion, they should have ran that thing to 7k vs the 6050 or whatever barely 6000rpm redline it was.
SHARKBITEATTACK
Enthusiast
St. Charles
Maybe using a V6 will allow him to stay in a slower class since it looks like its going to be a track car. Otherwise I don't really see any advantage of using that over an aluminum block LS motor.
Bru
Here's his reasoning for the V6:
I wanted a powerplant that would sit low and as rearward to the center of the car as possible. The v6 that i'm using accomplishes this feat quite well.
The engine sits further back and lower than a LS would. That was the only real decision maker. In fact, Its so close to the center of the car that its technically a mid-ship.
1quick
coal city
honestly if he does the turbo set up right im sure it will make 500hp thats plenty for a fun track car im sure
