Who is everyone's "go to" company for fuel hose and fittings?
BADAZZTEALCOBRA
Going to be shopping soon for fuel hose to run on the car, and wanted to see if anyone had any brands they liked or didnt like?
I currently have an Aeromotive Stealth tank setup with the 03-04 Cobra A1000 pump in it and one of their FPR's, and was going to be running their fuel filter as well.
One of my next purchases is going to be the hose and all the fittings though and was curious what some of you have used with success.
The only "must haves" are:
  • The lines will be -08 in size (both feed and return)
  • The lines must be black
  • The lines must be e85 compatible
Is anyone using PTFE lines? Is that necessary with e85 or are there other options that might be better suited for my build?
Anyone with a Coyote have fuel rail recommendations, or will the stock rail setup be good for a NA build for the time being?
GTPpower
Nebraska
I used all summit racing lines and fittings on my car with ptfe lines. No problems, no leaks. Easy to use.
1MEANGT
Braaaaaaap!!!
I used all Fragola lines and AN fittings. -10 feed and -8 return I believe. It all came with the complete BBRC fuel system I purchased when building the car. Good stuff.
Chris91LX
Crystal Lake
Fragola lines and fittings from racepartsolutions.com and summit
El Presidente
I can certainly check if you have someone in mind tho. I'm not familiar with this subject matter.
El Presidente
Fragola, for example, I cannot get...so....thats helpful.
Intel
Palatine
I have used Earls and Vibrant in the past. I just put an order in for Vibrant PTFE lines from Summit to finish up the fuel system on the Datsun.
BADAZZTEALCOBRA
BADAZZTEALCOBRA
Is PTFE the recommended hose to use for e85 stuff? Some of it is crazy expensive but if that's whats needed, then I'll go with it.
Intel
Palatine
The big plus is less permeability than rubber lines and compatible with E100/Methanol. There are plenty of rubber lines that are compatible with E85 but I would honestly flush them out with gas when storing over winter. I am only using about 4 feet total between bulkhead/engine as the rest of my system is hard stainless steel lines because I am a glutton for punishment.
03GTGreen
Cobra Brigade Presidente
Ive used the stuff from MMR with success
LikeABauce302
South suburbs
Also to answer your question, PTFE is E85 friendly. The other pro is that you won't get any fuel odor permeating like you may with standard rubber hose lining. Even if you just use regular 93 octane, the PTFE hoses will last longer. Rubber linings eventually break down.
BADAZZTEALCOBRA
BADAZZTEALCOBRA
So buy once cry once and go with the PTFE from the start. (y)
LikeABauce302
South suburbs
Yup. I'm kicking myself for not using PTFE in my fuel system. At the time, I didn't do any research and just bought standard stainless braided hose.
Pressure Ratio
Glen Ellyn
Earls is a great cheaper option. Fragola is great.
Most brands have low, mid, and high-end hose and fittings. So shop based on your budget. AN stuff can get pricey quickly.
A good tip is to buy swivel hose ends. Worth the extra money for sure.
BADAZZTEALCOBRA
BADAZZTEALCOBRA
Anyone heard of these guys before?
Their prices are a ton cheaper and appears to have a ton of great reviews? :dunno:
