To elaborate more on setup…if you have a lot of overlap in the cam, it can fill up the exhaust really quick. I’ve been out of the 3800 game for a quick minute, but I don’t believe there’s a ton of overlap in any of the off the shelf cams, nor do any combos utilize high rpm either. I’ve always recommended the smaller s&s headers over the larger primary headers on this platform. It’s pretty much all you need, and the packaging was better.
That being said, you might lose some TQ down low with the bigger primaries and on most setups it’s no big deal. You normally get a bigger stall and gearing and you don’t worry about anything under 4k anyway.
3800 is all about the wide TQ band with a 4 speed trans and the highway gears. 2800-4800 rpm is where this motor lives. This really needs to be considered to be realistic with goals. IMHO most of the time people build these things and make peak power in a shorter rev range rather than moving the rev range higher.
If there were better heads and readily available rotating assemblies capable of 7000+ rpm, I think the headers would come more into play.
