I went 13.2@104 with a 2.1 60' because junk all seasons. Premium is just fine.piss gas?
plenty of people had really solid S1x setups on normal pump gas...
s1x, ported gen 3, pacesetter headers and cant remember if it was a 3.2 or 3.3 pulley.in the summer e85 was most def worth using.
[MENTION=2449]ilikemtb999[/MENTION] that just on s1x and 3.4 gen3/gen5 no ic?
damn close to 12s with no ic and "piss gas"
nice.
not sure why that isnowadays only way to run a 3.2 is with a full intercooler stacked with a SSIC with an xpz and ported heads.
maybe its strictly mileage?
You crazy, if you hate it that much you should sell it. Something that clean will go for good $$. Especially with all the little things you've done to it.
I had some bullshit intense pcm and then a zzp one. I lost interest in it quick and didn't want to spend the effort to learn to tune or get someone to actually tune it. Oh wellA stock motor (turbo'd) on 14-16psi with pump gas will be more reliable and faster than an S1X setup. That's what I would do, especially if you already have it laying around.
As someone who tuned these cars, running smaller pulleys without proper flowing mods makes them impossible to tune. They're always picking up knock. Running a 3.2 doesn't require the sarcastic suggestions that KJ made, but timing will make more power than a pulley. My stock red GTP was 4mph off of your S1X mph, and it was just tuned on pump gas. Your car should have been trapped 110+ if it was properly tuned, 104mph means it had no top end, likely because it was pulling a shit ton of timing.
