When increasing rim size...
firemandan1700
Bite my shiny metal ass
LaSalle County
What needs to be changed using a tuner? I know there is something you change when changing rim size, I read it long ago but since forgot.
I have dhp
Eagle
Nemo me impune lacessit
Woodsticks, IL
Total wheel/tire diameter. I'm not a DHP tuner, so not sure where to change it, sorry.
10sec
Just remember, bigger wheel=heavy=transmission dying=more than you paid for those wheels.
Eagle
Woodsticks, IL
Does DHP have a nifty built in calculator for that like HPT does?
OffshoreDrilling
This is my safe space
Chicago
DHP has nothing nifty or cool about it at all. Its totally bare bones. and for the OP, you need to change the pulses per mile. There are some threads about tire size changes on the DHP forums.
TommyGloves
CHICAGO
What tire are you going to be running? It's all based on the tire size....not so much the wheel size.
The Broken Regal
BITE BITE, SIP SIP
Wheaton
x3 on pulses per mile
what size you going with?
Except that you don't have to license every car you tune with it... :bigthumb:
Otherwise, you might have something there! :rofl:
or you could have an original PT and ONLY be able to tune specific year/vehicle in w-body family and THATS IT lulz :roflpicard:
firemandan1700
LaSalle County
17" comp-g rims
They are currently wrapped in Falken 225-55-17 tires
If the tire diameter is the same- 225
I dont think a change is needed
best thing to do is get a rollout distance withthe car onthe ground and tire at proper pressure...but in reality as long as circumfrence is similar you shouldnt have a problem...you pulses per mile go up as you tire wears out, the difference can be as little as 40pulses per mile to 400
PANDA
FRG
Comp G rims on a 97-03 look dumb as hell.
Fish
From the mean streets....
Chiraq
^^ Twisty polished 5 stars, negative. 10 spokes, alfirmative.
10sec
x2
Stupid ^^^^ almost has the same name... The Irony... Those wheels look terrible.
bikrboy128
Some say.....
Wheaton
changing from a 225/60r16 to a 225/55r17 wont require you to change anything in the PCM.
when your speedo says 60mph, you will actually be going 60.2 ;)
nothing to worry about.
