Wheel repair western burbs
martyb
Active member
Daughter hit a pot hole in her ford 500 and bent the front rim bad enough to pop the bead on the tire. Was looking for a replacement 17" 7 spoke wheel with no luck. Anyone have recommendations on wheel repair in the western burbs?
Thanks all
Marty
SaturdaysGS
Chicago (Southside)
Rockauto will probably have it, or you can go directly through keystone (rock auto goes through them) I believe they are out of Chicago. Otherwise I've used Chicago wheel with good luck.
If it's just an aluminum painted 17" it should be around 150-200 for a refurbished piece.
EmersonHart13
Member Selfie
Another option is Wheels America in Elk Grove Village. For a stock wheel they should be okay.
martyb
Active member
Thanks guys, ended up with a new wheel and tire from discount tire, old wheel was too far damaged.
