What's the fastest eaton 03/04 out there?
Oncebitten03
Curious as to what the fastest 03/04 eaton is going. Don't care if it's auto/stick IRS/solid. More or less if it's got spray or not. Thanks!
gnxs
Corn-Fed Goodness
High 9's is the fastest I've read about personally. Here's the post, very crappy DA to boot (LVMS):
Hey Guys! I'm Frank,
I'm not much of the type to post on the boards much- I don't like drama, what I do like is going FAST! with a bit of a challenge (just ask Alex) and I really like how people always ask me "How I Did It" or "that's impossible". I see that optimization is key.
I'm very secretive and I'm just usually the shadow in the back ground because I don't like to step on anyone elses toes and I figured it's a waste of space if I posted one of my 10 second passes (My old setup was IRS 6spd, stock fuel system [email protected] race weight of 3930). I'm not new to the racing scene, I do my home work, and I try to be really dedicated as much as I can in what I do. I've have had my Terminator for about four years now and Alex and I have done everything to it, from building the engine to setting up the rear suspension to doing to auto conversion and tuning it, I just happen to be a bit methodical.
I'd like to say that this board has gave me a good foundation about modular fords
However, for those of you that know me know that I've been fighting the stock eaton war for the longest time (I guess you can say since I've bought my car
Last night it finally paid off! My full weight 3650lb race weight cobra, with not a single pound of weight reduction (well-weight reduction which I would consider untasteful)
that has the spare tire in the trunk has finally gone [email protected]!
(Well, 135.80
)For those of you that know LVMS, you know the air kinda sucks, the day was a 4400ft day and 95 degrees out. I started out in TNT going [email protected] twice like it was clock work, I thought it had it in her but my best buddy Alex (SVTboy) and Dana from VWR knew it had it last night to go a 9, Dana went out of his way to bring me 2 bags of ice. My girl got off work and immediately brought me 6 more bags.
They spent hours helping me cool my car down, charge my battery, while I made sure everything else was going to be on point. It ended up being the last pass of the night when I went the 9.93. It Eclipsed the 60' in 1.4 Seconds Flat. The eight in [email protected] and as I said above a 9.9!!!
Special Thanks to everyone that helped out!
My partner Alex from Voodoo for putting up with my shit all these years!
Dana Westover from VWR for always being there!!!
My Girl for all the nights of support while I worked and she stayed home!
I'm sure I'm missing some people, but all the people that came by to help, THANKS THANKS THANKS!!! You guys helped make this happen!!!
As for my mods, well since I do have countless nights of R&D, I'm usually a bit hesitant to give out the info...but I'll share what I have with you guys because this is the board where I've gained knowledge about mod motors.
It's an '03 Cobra of course
The car has full weight for the most part, what I consider to be tasteful (which is my opinion) weight reduction is taking out a part and replacing it with a lighter part that's just as durable if not more (Like Replacing K members, A Arms, etc). I don't have the heart to hack up a car that I love so dearly.
I have my stereo in it and I do bump it all the way down the track.
4.6L Built by Alex and me.
Stiegemeier Stage 4 Port (Thanks Stiegemeier for having a product that works, this blower has been through some punishment over the years!)
Ported 03 Cobra Heads done by Virtual Works Racing
Custom Ground Comp Cams
Hooker Headers
Dynomax Mufflers
60LB Injectors
150 Shot worth of laughing gas
BAP (The frikken thing works- It's hard to believe, but it does)
My Tune
QA1 Tubular K member and arms
QA1 Coil Overs
Granatelli Subframe connectors welded in by BSR Fabrications
MMR Upper Control Arms
Custom Lower Control Arms
Suspension Tuning by Alex
4R70W built by Performance Transmission Las Vegas by Len
(I didn't want to do this either, but the frikken T56 broke
and it was a bit spendy for a G force gear set that I didn't know if it would have definitely ensured survival )
Precision Converter
Some offbrand camber plates that I got as a gift
FRPP Driveshaft
Solid Axle (Trust me guys, I didn't want to do it but I broke 10 halfshafts from the last two years with the 6spd and it was getting a bit spendy, just ask Alex)
Welded Axle tubes from BSR Fabrications
Strange 31 Spline Axles
31 Spline FRPP Diff
JLT RAI
Dang, I didn't think my car had that many mods to it...wow!
I'm sure I'm still forgetting something, but you guys have the jist to it.
Anyways Good talking to you guys,
Frank
Grabber
Oh Hai
Wheeling, IL
Well, I know of a guy that ran a 10.48 @ 132.93 w/ 1.58 Stage 5 eaton, stock internals, upgraded half shafts, 6spd, IRS, and supporting mods.
His best time on NOS was 10.09 @ 134.52 w/ a 1.43.
Imagine if the driver of this Cobra had the mods Frank had, i.e Cams, Ported Heads, etc.
Some fast times out there, and some great drivers.
gnxs
Corn-Fed Goodness
Did he run that with a 4400 ft. DA?
Oncebitten03
Oncebitten03
I was reading about that guy on csvt, not bad!
A friend of mine's got a 284ci with ported heads and stage 3 cams along with a stage 4 eaton. And we have a C4 with a brake and modular bell sitting around and we're tossing the idea around as well as doing a dry kit back on it as well. It's full weight IRS with a brace.
10thSVT_03
DRRRT PROSPECT
Whats the fastest with an untouched longblock and just a port etc and no NOS?
ShelbyGuy
Turgid Member
vince [mystic terminator] and ralph corning [runs (ran?) a red 03 with wisconsin plates in midwestern council time attack events] are the fastest stock block eaton drivers i know of
Flatliner
I'm kind of a big deal...
It's the same guy I posted about Regis... his is without spray, but GNSX pretty much sums it up. We'll be seeing him up at MIR this weekend.
BADASS03SVT
Active member
Yep. @ ~135-136 mph.
He's supposed to be at MIR this weekend, so we'll get to check the car out in person.
too bad MIR didnt happen...hopefully come spring
anyone can look over my car at anytime :dunno:
and youll see no bottle and no marks on any of the bolts on the motor because its stock. I dont have anything to hide?
IZZy
Powered by ES
that sucks that it got canceled, we were really looking forward to seeing all the east coast cars:biggthump
