Whats a Good Clutch and aluminum or steel flywheel ???
sonic02gt
Kona Blue shelby
Car sees occassional track but mostly street i have centerforce dfx with 26 spline thinking about trying a different clutch any suggestions ???:dancenana:
FuelSlut
FK RED STAR
I had spec3+ and I now have the centrforce dfx . IMO the centerforce is a better all around clutch, less chatter less slip same torque specs. Just better street manners.
Unless u go twinn disc just stick with centerforce. And stay away from aluminum flywheels they are good for fast revving but they also make the Rpms fall between shifts like a ton of bricks.
gnxs
Corn-Fed Goodness
I've always had good luck with the DFX, but it's not for everybody (from a street manners standpoint).
I've always run a Fidanza Aluminum flywheel and the lighter rotational mass (vs. a steel flywheel) has never given me any issues with the rpms dropping between shifts or being able to launch hard.
S
sonic02gt
Kona Blue shelby
thanks for the input guys guess i should stick with the dfx :dancenana:
