What would you do? LSx guys chime in too
Smokinhot
3-man rules!!!!
Lansing, IL
OK, I found my issue with the ticking
Now my question is, do you think the new lifter would be ok after running on it?
I really want to change it b/c I feel its not, but I can't get the Head bolts and gasket before friday which the truck needs to be done by.
So if I was to get a lifter, can I atleast reuse the head gasket and head bolts. The truck has only been run maaaaaaaaaaybe 10 times and driven on once since I put the lifters, new gasket, and bolts on.
Can I re-use the gasket and bolt atleast If I did replace it? I've heard of guys doing it w/o issues
Eagle
Nemo me impune lacessit
Woodsticks, IL
Gaskets are cheap. Bolts you can reuse. Fawked lifter you cannot.
Glad you found it.
Smokinhot
Smokinhot
3-man rules!!!!
Lansing, IL
Thanks Dan, I was hoping to be able to reuse the bolts since they are the hardest to get. The gasket wont be a problem to get, and the lifter shouldn't either
Smokinhot
Smokinhot
3-man rules!!!!
Lansing, IL
but I need the part # for the LS2 lifter. Brandon was telling me about all these bad part #'s since GM likes to change their shit up
Eagle
Woodsticks, IL
Do that and you should be set man. Do it right and be done with it.
Smokinhot
Smokinhot
3-man rules!!!!
Lansing, IL
Yea, I'm not trying to half ass things just tired of tearing everything down..
I couldn't imagine your build
Runtz52
Manhattan
glad it wasnt in the bottom end, couldve been a lot worse, good luck with the rest of ur project
Smokinhot
Smokinhot
3-man rules!!!!
Lansing, IL
thanks
dan - The pan wont drop out b/c of the cross member. I've changed the oil out like 3 times already too. It'll be changed out this weekend too. Auto zone dealers FTW
bikrboy128
Some say.....
Wheaton
nice! no need to be messin around with the stock junk cam
i agree 110% with eagle. im sure you wont be very happy if the lifter in question damages your nice new bump stick. the gasket is questionable, but cheap enough to replace and not have to worry.
Smokinhot
Smokinhot
3-man rules!!!!
Lansing, IL
i'll try something, I pulled the pan and cleaned out the sluge before the block was set in the truck. So if there is anything it should be right on the bottom I hope. the magnet on the plug picked some things up too
smug
Cedar Lake, IN
So what causes a cam to pit or do stuff like the one you have there?
Smokinhot
Smokinhot
3-man rules!!!!
Lansing, IL
supposedly there have been quite a few over on performancetrucks.net. Well I had some shitty lifters the first round in.
Hopefully things can only get better from here...
Eagle
Woodsticks, IL
A to the RP
Hell, for his application even the stockers.
