I like heat ?Well, to a point an ignitor is an ignitor. But oem is the bestest.
I’m wondering if this is a flame sensor. The ignitor was replaced in 2016 and I could have sworn I kept the old part and put it in the box. The flat metal is what’s making me rethink it. Thought ignitors were rounded. ???
Receipt does say ignitor on it…
it’s and ignitor. Big list to cross reference.
Lennox 19W61 Hot Surface Ignitor
Trust Technical Hot & Cold for the right OEM replacement part. Buy Lennox 19W61 Hot Surface Ignitor for your Lennox Furnace new from the technical experts. Extensive product details, fast shipping, and expert supportwww.technicalhotandcoldparts.com
If you want to give it a try. More than welcome to use it till you get the replacement. This has about eight years of use on it, but was working. I’m in Carol Stream, can meet up to hand it off.Mine is flat as well. Between yours and mine, only difference I can see is the "base" mine is square, yours is round.
Enough difference for "them" to not cross it, but it would probably work.
Nope, just get the furnace up and working, it’s 20° out. Can meet to save ya some driving if you’re not close. I just need to get cleaned up real quick like.SpeedSpeak2me
Do you want anything for it? I can come snag it. No need for you to go out of the way for me.
I know my thermal sensor usually goes out every couple years but I just pull it out and lightly sand it to get some of the carbon buildup off. Furnace kicks on and stays on like a champ until next time. Your sure it's the ignitor and not an issue with the thermal sensor?
Damn. That sucks. Only decent place near me that usually have all odds and ends is a place in South Elgin called Sundberg America. Usually my goto if I can't find stuff online or nearby.Tried that last night and again today. No dice.
Depends on the chance you're willing to take. Is it worth the try to get the furnace back up and running or try an alternative plan? Especially with these cold days.Ace hardware in Mundelein might have a universal one in stock that might work. But that's still 40 minutes one way for a might.
Yes but after you can get wingys at franks next to that ace.Ace hardware in Mundelein might have a universal one in stock that might work. But that's still 40 minutes one way for a might.
There's a place in Norridge that carries a ton of stuff, things I couldn't find anywhere else. Let me see if I can find the name
Try give this place a call
You are not having a good day. Sounded fine when you pulled out.As I'm pulling into my neighborhood, hear a grinding noise, and car won't move under its own power. Had to push it a block to get home.
Hopefully that igniter works.
Just got everything buttoned back up. Furnace blowing hot air.
Not sure if I should be liking that post or be sad ?
