What is your best 60'
VenomInside
Just Grazing
SFO
Well, what is your best 60' and what was your setup/track you were at when you did it.
Wiked03
CSVT OG
Louisville, KY
1.52 at GLD. Built 8.8 on a 28" slick, launching at 5700.
I know there are some 1.4s in there somewhere. :headbang:
Shane97Cobra
1.43 - Stock 97 long block, S-trim, 6750 RPM launch, 28" slicks. Cut stock springs in rear, UPR upper and lowers.
Most the time on MT radials it is in the 1.75-1.8 range.
VenomInside
Just Grazing
SFO
is that with the 5 speed or the auto/stall.
Shane97Cobra
The 1.43 was with a 5 speed. My best w/ the auto so far as been 1.59. The converter isn't right yet.
The 1.75 ish stuff on radials I have done with both 5 speed and auto.
Zack
4 Doors 4 Life
NW Indiana
1.60
4450lb Marauder race weight.
BFG G-Force Drag Radial 295/35/18
Bigturbonotch
WAIT AND SEE
01 cobra on 17" et street radials, stock IRS, Stock Gear, 100 shot of juice.
gnxs
Corn-Fed Goodness
1.64 at Byron on the 275/40/17 MT DR's and 1.53 on the 26/11.50/16 MT ET Streets, also at Byron.
Solid rear with Strange 10-way adjustables.
doodad
275/40/17 nitto drags. 470rwhp launching at 3k RPM. stock IRS w/ IRS brace. 6-speed
Blood on Blood
rumble baby rumble
03 Mach 1
Stock suspension (literally)
5 speed
275 size nittos @ 17 psi
1.90 60 foot.
sschassis
Senior Nilater
VenomInside said:
What did you launch at and did you feather it out or dump the clutch.
hi Mike . :burnout: . i do ride the clutch on initial lift with 5000 to 6000 rpm
VenomInside
Just Grazing
SFO
hey nayle (i think i spelled it right :) ) nice!
How's everything?
sschassis
Senior Nilater
How's everything?
hey Mikey whats up everything its just fine thanks ... your close
this the way spelled ..... Nayel
VenomInside
Just Grazing
SFO
Good to hear. Thanks for the correction.. I knew i was close.
