What intakes are y'all runnin?
Synyzter
LS2 Power
As title states, and do you like it? Did you feel a difference?
Bob_Kurgan
Flyin_Hawaiin
ive personally tested a bunch on my own truck and the AEM, with its built in maf mounting flange, made more power then the JLT and K&N...
zenriddles
Molon Labe - come and take them!
Holiday Inn
I made my own. By hand.
You 'mainstream' engine guys are spoiled rotten.:rolleyes:;)
Bob_Kurgan
Flyin_Hawaiin
ive worked with a number of CAI companies and some of them have the same though process as you. Some of the companies think that bigger is better and thats it.. BUT, i have worked with companies that have airflow engineers and software and it's quite an eye opener... when a CAI is designed properly, you can actually see a big difference over some oversized PVC tube.
zenriddles
Holiday Inn
Let me restate that for you.
An entire intake manifold from throttle body to heads, fuel rails, the whole 9 1/2 yards, out of aluminum, some bolted, some welded. Including positive displacement supercharger.
No PVC hot air intake here, Sir.
Bob_Kurgan
Flyin_Hawaiin
I understand for proper gains, but I'm just looking to replace the stocker at the moment. I don't have the coin for a tune yet.
the JLT will require a tune though.. i would stick it aside until you can afford a tune.. it leans out the a/f as much as 10%..
peteraugusts
New member
Well, I decided to run my car today with a stock Contour SVT airbox and a paper filter. The car has always felt faster with this intake, but I always refused to believe that it made more power than an open K&N filter.
Unoid
Libertarian Massa
I was running around WOT with JLT RAI no tune.. Never knew it needed a tune!
Glad you hooked me up 2 weeks ago with one.
jvert
Go Bulls and Cubs
AEM for my lightning and its tuned buy Bob Kurgan.
