I've read the K series motors usually sit too far forward on older body styles. which = poor handling
Yep, if you're going to boost..fuck VTEC. All the power of VTEC is in the near redline RPM range. With a turbo you'll be shifting before that because it will be in it's inefficiency range. And you need an LS transmission anyway for the longer gears to build boost and not have to shift to third quick just to build pressure.
you should run mandys brother when he swaps in his k24 into the CRX
run from a roll... after all, you are both ricers
all hondas are rice.....IMO of course
no.. just zacks :hay:
I remember seeing that car for the first time and remembering that you could fit a soda can into his exhaust tip
you could probably fit a 2 liter bottle in mine....
I myself wouldnt waste any money, but if I was you since your going through with the trouble of a engine swap why not get a better engine? I wasn't aware of the outrages costs of these motor swaps.
what is the shape of the motor. did you do a comp test before you pulled it? atleast it is a auto motor. You will like the ls and the TQ they make over the vtec motors.
Its because of ricer markup. Same reason supras, rx7s, 240s, etc. are so overpriced.
LS Turbo>Vtec.
LS motors are strong as fuck.
Screw the haters, Id love a turbo'd LS hatch.
At least down the road if you want vtec you can do the swap fast and cheap. This swap isnt like the mine-me swap. the ls block is the same deck height as the b18c blocks. So you just have to use the vtec waterpump,oil, timing belt. goldeneagle makes a fast and easy swap kit. have fun and boost the shit out of it. just dont be cheap on the tuning, that is the biggest part on the turbo honda's. ( same as with everyother car)
