đź’¬ OT What are you working on today?!
NO PUKESTERS
95,702
$500 tow for a vehicle with dirty air filter
NO PUKESTERS
95,702
Nah moron in winter maintenance likes to pull things out of the way instead of removing stuff. He says its faster. Sooo fan ate clutch wires. Ate blade. Will try and booger it and see if it blew the head gaskets running at sun surface temps for 3 days.
Yea if those clutch wiring bundles aren't perfectly placed they will eat em up.
NO PUKESTERS
95,702
He had a few up top oil leaks he wanted fixed...
I said man if you want oil leaks fixed, we aren't going to fix any of them unless you do a pan too..
You know how it goes, you fix 2 leaks and then 3 months later you get mf'd cause it's leaking again...
It's either all or nothing with me.
So he said yea fix it all.
Bob Kazamakis
I’m the f-ing lizard king
85,557
45,805
Joel
Swapped the pre cat oxygen sensors on the Yukon, they came loose with an open ended 7/8 and didn’t break a single clip :fy:
also replaced the heater hoses on the cucv and moved the temp sensor to the coolant crossover instead of in the water pump, hoping to get a more accurate reading since that’s behind the T stat.
