FedEx truck with a banger... This thing is a beast. 7.3
I don't get dirty hardly ever.some days when you leave work do you just have a fellow worker hit you with a pressure washer and some degreaser or what
I hate being greasy or oily. It happens.. But very rare.
Pump in the valley went out and I wanted to get it in the shop so I rigged up a outside fuel source to get er rolling.
Think I just stumbled on a big SNAFU.
I pulled apart a turbine flow meter this morning for maintenance in our chilled water loop. All the stainless parts were covered in a copper deposition. A couple weeks back I noticed the same thing on a stainless strainer basket. No bueno. As soon as I saw that I knew something was up.
I should note we recently started adding sodium silicate to the water for corrosion inhibition. Sodium silicate forms a film on the pipe walls that self heals as it gets corroded away. Well, it doesn’t do as much on copper as it does on steel or ductile iron. So corrosion now moved from easy to munch steel to all the copper coils and HX and is depositing on other surfaces.
sodium silicate is pretty common stuff. It’s dosed in potable water distribution all the time, especially where there is lead pipe still in the ground to reduce the amount of lead leeching into the water supply. Flint, take note.
Luckily, passages on most HVAC shit are large enough diameter where that’s not an issue. We run pretty low concentrations too.When it drops out of coolant it clogs coolers and filters.
napa had this 4 strip kit on sale for $125 bucks. i highly suggest it.Half of the career is finding and paying for good lighting
They look wired?napa had this 4 strip kit on sale for $125 bucks. i highly suggest it.
They look wired?
