what all should be replaced?
Kyle
Downers Grove
Well I've been doing what I did before I got the gtp and have been stock pilling lots of random parts.
suspension is one of the first things i plan on tackling.
I have the gmpp handling kit (sway bars and trailing arms), but havent gotten the replacement bushings or anything yet, par#s anyone?
I also have eibachs and I'm going to get konis from the wbody store as well.
What else should i replace? strut mounts? both rear and front?
looking for ideas, since i'm gonna have this all torn apart i'm going to go ahead and put on my new rotors and probabally paint my calipers at this time too.
any other things that I should do while the car its torn apart like this?
thanks in advance guys
kyle
Fish
From the mean streets....
Chiraq
Strut mounts are a must I think. I thought the GMPP handling kit came with the bushings.
Sounds like a good setup.
Kyle
Downers Grove
i bought it used, so it did not.
and i basiacally just dont wanna be another kyb/eibach person complaining about their ride.
and the bmr stuff is expensive and heavy so thats why i went with gmpp.
i think this should hanlde alright, all i really want is it not to feel like i'm driving a land boat like these fat ass cars really are :lol:
Fish
Chiraq
I hear ya. I also heard that BMR sucks. Thats why they dont sell their parts anymore.
When I read the suspension forum on clubgp, I dont really hear that many complaints about KYB/eibach combos. They usually do the anti-pogo mod and that usually helps out alot.
I
imported_Ron Vogel
Don't bother with the rear strut mounts. The fronts are a must though. I've changed out several sets of srtuts on different cars and the backs really don't see wear. You're going to want to get new spring cushions for all 4. They're cheap too. I have one new one for the rear you can have if you want. It was backordered when I did mine, and didn't want to wait for it before the install. The endlinks for the rear are pretty solid too, don't bother with them. The GMPP sways come with rubber bushings, in the long run you'll want to use them. My poly ones have been a PIA since they went in. I would suggest poly's for the front bar endlinks.
Trust me when I say this, rebuild your front lower control arms or, buy complete ones while you're doing all this. I didn't and now it has to all come back apart to replace them. If they wear, you'll get a lot of torque steer.
BTW, to do this job you need a powerful impact wrench. Or it will take an awfully long time. The biggest PIA is to get the bolt that goes through the rear knuckle to the trailing arm off. The bolt freezes in that pretty bad.
With a good set of power tools this should take roughly 4-5 hours for the complete job. If you need any help let me know.
Fish
Chiraq
My rear strut mounts are squeeking hardcore just putting the car in gear. Driving on a bumpy road requires the radio turned up louder.
Royalgtp
id recomend the GMPP koni kit in minute. Real easy to install.
Plus, you have a complete strut/spring/strutmount/etc/etc.........all as one complete unit.
Just slide it in.
Way to much work involved switching out the strut mounts/springs.
CoolGTX
let sleeping dogs lie
Hotel 4 Dogs
Just slide it in.
[snapback]68405[/snapback]​
so, what was the outcome of your bad GMPP/KONI strut?
Kyle
Downers Grove
[snapback]68360[/snapback]​
do u happen to have the pn for lower control arm ron?
also when I do this i might give u a call just to have someone pointing at things telling me what to do. and I should have air tools at the garage i do my work at by the time i do this also.
I
imported_Ron Vogel
Don't know PN, but I know it exsists. Comes in one assembly for the lft/right sides (2 different PN). If you need some loaners, I have 3 air impacts too. IIRC someone on here got them for around $110 each on GM parts direct.
Royalgtp
I was to busy at school. Left it alone and am now out of the warrenty period I believe. The one is about 3/4 higher.
cpk71
elmwood park
change the strut mounts its cheap insurance as long as you have everything apart.
