[MENTION=12]Bru[/MENTION] hows the diff fluid look?
is it possible that the carrier bearings just shit the bed and that noise is resonating through the driveshaft to the tail?
i talked with Carl here at redline powertrain and he said he has never seen a case or tail bushing cause a noise like that
I changed it before TCG Tour 2016 using GM LSD additive, so like 5,000 miles ago.
Hmm, carrier bearing. Could be a possibility. I swear the noise is coming from the tail shaft area, but acoustics are weird under there, especially when it’s up in the air on the ground.
Marty installed the gears at your shop back in 2011, and you ordered the gears and master install kit for me. It’s only been about 12-15,000 miles, so maybe not the carrier unless something else has worn it out.
