went to the track
SleeperLS
Desert Racer
Sandia Mountain
Well, I didn't get what I wanted but I did still hit a pb. 60 foot sucked at a 2.09 but I got a 13.07 at 107.4 mph. I have slicks, just didn,t use them. Also, I need a fuckin tune. I didn't have a blip of kr at all so I need more boost. Best place to get a tune in illinois?
GTwolf
I hear 10secsomeday does some good shit, I'm going to him as soon as he has time/it's warm enough/I finally figure out what the fuck is wrong with my car.
SleeperLS
SleeperLS
Desert Racer
Sandia Mountain
Gateway international raceway st. Louis. The track was nice tonight too. A kid in a 06 stang gt was rippin it. He had all the bolts ons and cams, also had street slicks. Ran a 12.4 at 111 or 112mph. Mustangs are fast with mods. First one I have seen run that well with motor though.
OffshoreDrilling
This is my safe space
Chicago
puhlease, I do that without slicks and in a truck that weighs about 1000lbs more too. :ford:
PANDA
FRG
Its cool that the tracks down south are open already. What kinda timing you running with that setup? A tune will not give you more boost.
DanJoy
I think he means that since he had 0 KR on an untuned car he should be either running more boost or timing to maximize the potential from his setup.
SleeperLS
SleeperLS
Desert Racer
Sandia Mountain
That's a bingo. I need to order a smaller pulley. I think my timing is at 21* last time I checked. I upped it recently but heard to not run too much more than that. E85 is crucial though.
My oil pressure gauge is reading 0 right now, but I don't think I can believe it. I am going to check wireing today. I lowered my car last night and am thinking something got pinched or pulled. Any other ways to manually check and see if my motor has oil pressure?
Harbor Master
if its still running... i would like to assume it has oil pressure.
ilikemtb999
I eat dirt
Denver, CO
So you're running untuned?? Or is a new tune going to net better results? I feel like that's slow for the mods....Mph is high for your et so that's good
Is it a mechanical or electrical gauge? Electric sending units suck. Pull the filler on the valve cover and see if oil is coming out the pushrods.
SleeperLS
SleeperLS
Desert Racer
Sandia Mountain
Yeah, my time licks nuts compared to what I should be running. The heads are home ported to stage 3 specs, not cnc so I don,t expect the exact same performance. But I have never had a good tune on the car, and once I switched to e85 I just changed the injector tables. I am only running a 3.0 pulley as well. The car just needs to be tuned up really. The best tune I had was years back when the car first got put together. I have changed everything but the cam since...so I think a tune would help significantly.
The gauge is electric...get a new one then? Wires are fine and I have oil
