Well I'm off to ZZP
Xtant12
So I leave at 4am in the morning to go to ZZP for my dyno tune. They said about 2 hours and I should be covered. Panda said I will only get 300whp so I will set my bar for 320. Anyways, I plan to see the new drag car they are building and check out the shop. Ill take pictures and videos. I feel like my car is finally going home!
boostedguy05
not well known
4AM Tomorrow morning? or you left 12 hours ago?
either way good luck!
i wonder if they still have [MENTION=917]1quick[/MENTION] 's white 04+
Jfrost
Fiero's are addicting
Brookfield
Good luck on the tune! Looking forward to your results and pics of the new shop.
Bru
My guess is 280 with issues
Xtant12
Well I'll own it, I did not hit 300 bit it was close. My average for 10 pulls was 285 and 360 torque so I'm pretty happy for that. One of the best was 293 and a 291. They did 31 pulls including 10 hard pulls. They did an awesome job. I met Zoomed and Turbo Tim. They new place is sweet. I did not know the make there own parts. They had a guy welding pipes they made together to make the down pipe. It was crazy. They are building a drag car for Chicago next month. It had no front end when I seen it just motor and intercooler. I was very happy with the out come of the dyno tune. I noticed on the way back I gained about 3 or 400 rpm. The rpm at 85 mph dropped so that's proof things are better than they were. They said for a stock cam I should be proud of the whp it made. All and all, I'm happy!!
Xtant12
ill guess 305, wheres the numbers
Yeah they said my af and timing were all over the place, but they fixed it. Also at max rpm I had a misfire on the dyno so they pulled my spark plugs out and re gapped them. Good guys!
Xtant12
Thanks!!
Also only 10 pulls were for the max power. The rest were to tune the maf, af, timing, ect
Xtant12
Yes a lot, but I think I have to utube them the I can put them on here
10sec
10sec
I'm sure they were part throttle tuning pulls. You can't just strap on an untuned car and give it the beans.
PANDA
FRG
Good job XTANT now get some 1/4 mile times. I told u the car would be right in that ball park. Its good they did 31 pulls, and not a 3 pull and done "Modern Muscle" tune.
