Weird issue with new car - Caddy stability control kicking on
Angus
Bentonville, Arkansas
To replace the Dart, we picked up an '04 SRX and have experienced a couple of times the stability control system kicking in on tight slower turns, like turning into a tight parking spot. Or last night I was at a gas station and drove over the tank caps while turn and the system kicks in and kicks in the ABS...
Anyone know where to start looking to see what needs to be replaced or repaired? Did some searching and saw other owners complaining about the system kicking in at 60+ mph and pulling the car into other lanes. This isn't what I've experienced but has me concerned with this system as well...
Any experienced GM/Caddy techs?
TIA!
Dasfinc
Mrrrrstang.
Wheaton, IL
6 or 8cyl, and AWD or RWD?
Maybe the ABS sensor in the rear diff is coated in shavings/sludge?
RICH17
Dr. Pussy Slayer, MD
The 007
Why did you get a SRX???? Such shitboxes
Harbor Master
Says the guy with the rusty lumina.
Srxs are pretty decent. I put offers out on three. I dig em.
RICH17
The 007
They're nice. But crazy expesnive to work on or get any parts for. Dealer for almost everything it seems.
bikrboy128
Some say.....
Wheaton
the speed sensors are in the wheel hub, not differential. chances are one is bugging out at low speeds, which is really common on GMs. get a scan tool and watch each wheel speed when it happens. i'd bet one drops to zero
I replaced the sensor in the steering column when my Caddy Stability Control was misbehaving. Use the onboard diagnostics to get the codes and then check them on the internet. They'll probably tell you exactly which sensor is misbehaving.
