Water Temp gauge fitting
Jack1
I removed the fitting on the driver side of the engine block when I installed my mechanical water temp gauge, and now I'm remove the gauge and need to put that fitting/plug back in... but I can't seem to find it, nor do I remember what it looks like.
anyone know the type of plug, thread info pitch etc?
anyone have pictures or description?
Thanks in advance
Dana
Bluesmobile
It is either a 3/8 inch pipe plug or 1/4 inch pipe plug, but I think it's 3/8's.
It is just a standard pipe thread, nothing special. Any type of head you can find will work, but they usually come with a hex head from the factory.
Ace hardware or Menards will have them.
Just put some teflon tape on it.
Dan
Jack1
Jack1
Dan
Brian (Vobraman) stopped by and brought two similar plugs, a 1/4" and a 3/8", he said one was for the coolant and the other for the oil gauge.
the 3/8" plug had white residue on the inside, while the 1/4" was clean and shinny. So I figure it has to be the 3/8" one.
hopefully I can find it in my garage.... I remember saving it.. just don't know where it went since the move.
