Warm weather vs. boost
Dragon03
Super hated on
I have a question for everyone who is running twin screws. Getting on the highway this afternoon I nailed it and in looking at my boost gauge i was hitting right around 14 1/2 lbs and then stayed right below 14 the rest of the climb. I know that warmer weather does make the blower work harder hense more heat less horsepower/boost. Since this is going to be my first warm time of the year since going with the Whipple are you guys seeing about the same amount of loss regarding boost (2-3 lbs)? I have been a little suspect that I may be alittle fat in my A/F or atleast thats how it feels. Thoughts? Or am I just spoiled from going out and playing on those nice cool boost friendly days :cool:
rdsnake
formerly RD SNAKE
You hit it pretty much on the money. my little 2.2 blows in the heat..time for a 2.8H!
Cobratom
Much worse here in Arizona too!
The heat is one of the reasons adding a nitrous shot does so much for blown cars. Besides adding power through a more potent fuel/air mix, it also cools the intake charge getting added hp from the intake temps.
Dragon03
Super hated on
What are your thoughts on that methanol stuff? I entertained the idea but after looking into it there were issues with it stripping the tefleon coating off of the blower internals? I think the only way that stuff works on our cars is if you use it post blower??
gnxs
Corn-Fed Goodness
I typically see 1-2 psi less indicated boost when the ambient temps go up 40-50 degrees.
I've never tried methanol myself or talked about it to anyone who uses it. Some people like it and some don't. If it's stripping the Teflon off the blower, it might also affect the coatings on valves or other internal parts. I don't know for sure.
gnxs
Corn-Fed Goodness
Next time I see you at "Streets" or wherever, I'll give you the complete lowdown on methanol.
01GTvert
Wamer ambient air temps always make for less boost..this being because warm air is less dense than cooler air. Methanol works great for PD and screw type blowers. Many GTP/GS guys run it (I did for awhile) in their non I/C'd M90 setups and report their blowers are ice cold after repeated WOT runs. The higher the concentration of methanol the more chances it'll strip the coating off the roaters but on the M90 (and presumably the M112) that coating is only there to reduce noise (as per Eaton themselves). There's a few quality meth/alky kits out there worth looking at.
Dragon03
Super hated on
Thanks and either that or at the pinic that is coming up here pretty quick.
gnxs
Corn-Fed Goodness
I'll be out of town that weekend. :(
