Wasn’t you who said cheap ones and replace often? That’s the logic I have been followingI’ve got 5” pleated filters. Still clean after 6mos.
If all you have is a 1” filter, yea. A 5” filter has something like 5x the surface area to not only capture particulate but distribute the pressure drop across the filter.Wasn’t you who said cheap ones and replace often? That’s the logic I have been following
I lower it at night just for comfort. We keep it 72-73 daily and 69-70 at night.For you guys that lower it a couple degrees at night. In reality, how much money are you saving? Ours stays at 70 all winter long I’ve never lowered it at night because I can’t see you saving that much money.
70 is usually too toasty at night. I drop it a degree or two. Sleep much better. With the temps as cold as they are I just leave it at 70.For you guys that lower it a couple degrees at night. In reality, how much money are you saving? Ours stays at 70 all winter long I’ve never lowered it at night because I can’t see you saving that much money.
.038? I’m paying .10 and some change and thought that was super highOnly paying $.38/therm to Nicor and rate is fixed for 4 more years. The last 12 months has seen Nicor go from $.28/them to $.68. It’s been a crazy year.
ComEd I’m still on their normal rate but I signed up for community solar since I’m not qualified for rooftop. Wont save much but it will be about 10% cheaper than ComEd once the project goes live.
Nope definitely gas and it’s high for this area of Illinois.10 must be your electric
Yes I’m dumb Lol, .61 is correctThat is a delivery charge (which Nicor has also increased).
If you don’t have a supplier your cost per therm is listed on the left side of the bill and will say gas cost rate under the delivery charges. Should be $.61 for January. Also the bar graph shows Nicor’s price per therm for each month.
If you have a supplier it will be on the right hand side like mine.
Lol, all good. I sell energy so I’m used to looking at bills.Yes I’m dumb Lol, .61 is correct
Sell me some .038/therm gas...[emoji41]Lol, all good. I sell energy so I’m used to looking at bills.
I set mine at 73 or 74 during the day. At night it's set to 69. I don't do it to save money or anything (although that helps), but so that my kids sleep harder. They tend to sleep better when it's a little colder in the house, and having a kid who has sleeping issues, we make sure to do what we can so she can possibly get a good night's sleep.For you guys that lower it a couple degrees at night. In reality, how much money are you saving? Ours stays at 70 all winter long I’ve never lowered it at night because I can’t see you saving that much money.
Definitely not too big for a single furnace, moreso a limitation of duct design. Residential duct systems are seldom optimal for the reason of expense, proper sizing cuts into too much living space, and the residential side of the industry is very stuck in their antiquated ways of rules of thumb. “I’ve been doing it like this for 35 years with no problem” crap.$198 gas
$182 water and electric
3,100 sq ft of conditioned space. Single furnace, Lennox Elite with advertised up to 98% efficiency.
The house is, I think, too big for a single furnace because even in winter the upstairs is cooler than downstairs, or it’s inefficient ducting. The farthest room (our master) is constantly a few degrees cooler than the rest of the house. Much better, though, after going R60 in the attic and playing with the ducting dampers, which made a huge difference. And also using the low-speed fan to keep air circulating. Im using fewer therms than last winter, though I haven’t looked into avg temps yet.
Same sq ft here. I have a single unit but my floor plan is open main floor with vaulted ceilings. Once I got the ecobee I monitored the sensors for which of the rooms ran hotter. Just two. I also prioritized the sensors in terms of which ones participate. Using them all for an average temp will lead to increased variation.$182 water and electric
Yeah, I did the same with Nest sensors. And also a handheld anemometer on the vents while playing with the dampers; not sure if that was useful (pressure vs volume), but I’m at a point now where I don’t have to set the temp to the kids’ rooms to make it comfortable.Same sq ft here. I have a single unit but my floor plan is open main floor with vaulted ceilings. Once I got the ecobee I monitored the sensors for which of the rooms ran hotter. Just two. I also prioritized the sensors in terms of which ones participate. Using them all for an average temp will lead to increased variation.
Main floor master and the center of 3 bedrooms upstair were my the ones mostly off. I added flair vents to those rooms. My temp variation is perfect now.
The flair vents and integration with ecobee is great along with the data it provides.
$128 comed
$266 nicor this month!
this gonna suck. woof.
