GTPpower
6,350
9,752
Nebraska
Meh.
By the way unless that's the core that prj modified for a post-core boost bypass passage for the external boost bypass valve.
delete the Boost bypass valve if it does not pass through the intercooler core before getting recirculated back into the blower.
The animal kit does that and it's a s***** compromise.
it's what led to lunching the Whipple on The WhippledRiv
I haven't looked at it too close yet. But I'm pretty sure it's what prj modified.
Reactions: Turbocharged400sbc
32,643
16,111
I still can't believe prj and John Bob had that custom 90mm throttle body plenum made when Whipple told me the 90 mm throttle body was too small and that they use their own custom giant throttle bodies....$$$$.
I verified it with a vacuum gauge behind the throttle body and they are definitely right.
It's nice that you got the later animal throttle body plenum set up with the angled Machining.
turtleman
Addict
Sep 6, 2009
831
823
Villa Park, IL
covid
I still think the only viable setup is the 3.3 or 200 ax that way you don't need a 3-in pulley and the resulting belt slip and wishing you could buy a 1000ft roll of belts
it (the 2.3L on a 3800) is self-fusing for people that have intermittent self-control problems like myself. If you ask for 30psi, the belt says "no, stupid!"
turtleman
Addict
Sep 6, 2009
831
823
Villa Park, IL
covid
What belts do you run? Chessler seems to have good luck with the gates rpm belts since they don't stretch.
i didn't get past the limits of my standard gates belt, belt wrap and 7.3 powerstroke tensioner while i had the old car going. I'td get to 20-22psi. i was kinda eyeing those rpm belts but i feel like it's a whole different strategy. ill visit that once it's the big problem. only issue i did have is when im bouncing off the rev limiter and doin hoodrat shit the belt could work itself off and shred
GTPpower
6,350
9,752
Nebraska
What did you have to do to get the 7.3 tensioner to work?
