32,623
16,056
um....leakdown is in %
your suppossed to set the pressure and the % difference between the pressures on either side of an orifice is what your looking for......% of leakage
also leakdowns at BDC/TDC are not super accurate even on nearly new bores compared to at 30* BTDC/ATDC/BBDC/ABDC old dirty ring packs may need a nudge to get the rings to set in their grooves
dont shortcut the cranking cyl press test, pull all plugs before test begins after driving the car for long enough for operating temp, block/hold TB open
you can kinda shortcut with not getting it more than warm (so ya dont burn yerself so bad) but readings are a hair lower than at operating temp
i hope youve been looking at your pre AFC MAF Hz from the begining of your project.....as thats a great overall indicator of engine airflow increase/decrease....you can use post AFC data just as long as youve never adjusted the afc and the sensor is regularly cleaned.
L67 comp test will be lower than the NA shorty. making sure one isnt way outside the mean is the main goal
Reactions: sktchy and TurboTPI
GTPpower
6,345
9,746
Nebraska
I got tired of trying to test this intercooler system with a 1.2 gallon compressor that works great on lawnmower and bike tires. I grabbed my 60 gallon compressor and stuck it in the garage. It's nice that I can test it without all the noise from the little compressor running.
The bad news, I still am not finding any leaks. So why will this thing only build 10 psi? Did I mess something up by cutting the inlet off? The coating looks good on the rotors and I don't see any red flags there. Should I go to the junkyard and get another gen 5 and try that?
Reactions: sktchy
sktchy
7,816
12,036
I wonder if we aren't having any least some sort of similar issue here. Granted I've got some mechanical issues to sort out but I should be seeing 13 or 14 psi at wot where the gate is sprung. It sees 12 max if I'm lucky even before I ended up with noises to deal with. Same thing on the last motor.
I know it's not apples to apples and mine may come to light after further research but it's something that I haven't been able to explain yet unless it's a weak wastegate spring or something else of that sort
Reactions: GTPpower
JST_A_3800
Jan 2, 2022
24
87
nick you should install a boost port in the blower hat and see what the pressure drop is from the blower to the lower intake. I assume you are measuring boost in the lower intake. I just can't help but wonder if you have a flow issue with a couple of the bends you had to make in the intercooler piping? then if it is only making 10psi under(above) the blower that may narrow down whether its an inlet issue or something down stream
JST_A_3800
Jan 2, 2022
24
87
I even have an extra 20lb boost gauge laying around if you want to borrow it if you don't have an extra
Reactions: GTPpower and sktchy
GTPpower
6,345
9,746
Nebraska
That's a good idea. I'll order some more aluminum bungs and weld one in there.
The outlet from the blower is maybe 3/4" tall, but it's about 5" wide. Other than that, all piping is 3" and the intercooler is 3.5". But, I do know that where it goes into the lim, it does sneak down to less than 3"....how much less though, I'm not sure. But I am measuring boost before that point.
But this is a good idea. And I should hook up my intake air temp gauges as well while I'm at it.
Reactions: v6buicks
JST_A_3800
Jan 2, 2022
24
87
do it nick!!
Reactions: GTPpower
sktchy
7,816
12,036
Seems like everyone here is big on the 1/8 mile stuff lately. There's kinda of a little drag and drive from here to i29 towards the end of April that'd be fun to make if I can find the ambition to pull mine apart and put it back together again by then.
GTPpower
6,345
9,746
Nebraska
I haven't. My wife goes on maternity leave starting Monday, so I will be at home with her for a week. Should be able to get some work done on the car then. I also ordered a 3 bar map sensor, so I will plan on using that in the new port.
But I also have a scissor lift and 6.0 to fix as well. So we'll see how much time I actually do have.
Reactions: sktchy
sktchy
7,816
12,036
I'm not sure what kind of voodoo it takes to get those to stay on but I've never been able to get one to stay tight even with the tool. It's not real proper but a couple worm gear clamps clocked 180⁰ from each other seems to work pretty well without throwing things off balance.
Reactions: GTPpower
