Site Sponsor Twin Turbo Demon 170 - Hellion Turbo 68mm Compound Boosted
Satera_Tuning
Figured we would post some teaser shots of this in preparation for final results coming next week
We have been given the opportunity to handle the tuning of this beautiful machine. The owner worked closely with Hellion for the adjustments needed to Hellion's base kit to bring this setup to life. As you will see on the pictures it is tagged as the 3rd kit produced by Hellion for the D170 application.
Here are the details...
2023 Dodge Demon 170
🟢 Hellion Turbo Systems 68mm Compound Boost setup
🟢 ID1700x Injectors
🟢 Fore Innovations Triple Pump Fuel System
🟢 NGK 2309 Plugs installed
🟢 Stock Upper Pulley and lower pulley reduced to OEM hellcat size.
🟢 Customet chosen Torco 118 oxygenated and leaded race Fuel on deck
We will be sharing everything we learn next week on our live Vlog Series on FB.
Right out of the gate we can tell you these PCM's do NOT respond to adjustments the same way prior hellcats do.
We have also pumped 28psi+ of boost through her with zero issues.
At the moment wastegate Boost setting is around 21-22psi. And we will be targeting around 29-30psi on full send Boost settings.
We already have acquired a ton of data.
Stay tuned as we wrap up testing next week when we reveal final numbers.
