🔧 BUILD TURBOCOP - The Poor man's Kitty Cat - Turbo 6.0 Caprice
Because I can’t afford a hellcat I got the Caprice for a fun 4 door daily. So I after I got the Caprice and drove it for a little while I noticed the motor made some small noise every time the DOD kicked in. So I decided to look into a DOD delete kit. With work being so busy and not having a garage I decided to just have Next Gen Built Performance out of Elmhurst do the work. So I dropped off the car and they got to work.
A simple cam swapped turned into
-Melling HVHP oil pump
- Billet timing gears with IWIS chain
- ARP headstuds with LS9 headgaskets
- LS7 lifters with new trays
- LS2 chain dampener
- Trunion upgrade
- BTR .660 platinum spring kit
- custom turbo cam (for future build)
I decided to still keep stock exhaust for now so it was kind of a sleeper at this point. The car ran strong and the cam was pretty choppy for a turbo cam. But the idle sucked gear because of the cam. So then I decided to start buying parts for the turbo kit. It’s a custom G8 kit built from Next Gen Built Performance.
So I picked up
- fast 85 injectors
- kenne bell bap
- circle D converter
So then the plan was for them to build the kit and then I was going to install it I wanted to save the money and I wanted to feel like I built some of the car lol. So I put a deposit down on the kit in July I think and waited, then waited, and waited some more. Finally got the message that the kit was ready but they needed my car to custom fit the intercooler and stuff.
So I dropped of the car and they got to work on fabbing. Once the fab was close to complete he made sure I wanted to install the kit myself and I told him I did because I didn’t want to pay for it. He came back a few minutes later and offered to install the kit minus the injectors, bap, and converter for free to be sure the figment was exact and I would be happy with everything. So as bad as I wanted to do some work myself, I can’t complain with the free labor and aim to please me.
The turbo kit includes
-Driver side Schedule 10 Stainless steel Turbo header
-Schedule 10 Stainless Steel cross over pipe ( OEM flange pass side to v band on drivers side)
-3 section 3.0" down pipe from turbo to trans tail shaft area (has 3 v band break outs for ease of install and servicing) 3.5" splits into dual 3" at trans tail shaft area for catback hook up)
-3" aluminum turbo charge pipe to intercooler
-3 to 3.5" post intercooler charge pipe( for SS factory maf housing)
-Comp Turbo Billet 76/75 T4 Turbo (Billet wheel anodized to your color choice) Ceramic coated turbine housing and a polished or powder coated compressor housing
-Tail Q50 Blow off valve( your color choice)
-Tail MV-R 44mm wastegate (your color choice)
-Massive high flow 18"x12"x4.5" intercooler
-couplers and clamps
-replacement engine mount bracket
-oil feed and return lines
-replacement washer tank
-replacement coolant reservoir
- 02 extension harness
-main power post relocation bracket
- single bar mild steel replacement bumper support
I still need to go pick up the car to finish with the stuff I need to do and then get it tuned. I will be switching to a squash performance fuel pump so I can get dat E85 tune, just not sure if I’m gonna do it now or spring. I’m hoping for mid 600’s and lots of fun.
And the money shots
I also had them connect the exhaust to the stock exhaust but with a loud valve for that sleeper effect.
And the sexy camera pics
Pro Stock John
LS is the best engine
10,599
14,511
Chicago North Side
I really need to learn how to drive the car, it should be a mid 9's car all day. I just get nervous and have very little driving experience at a track.
What part makes you nervous?
There are two things I get a little worked up about, doing a good burnout and lining up straight in the groove.
For the burnout, I angle my driver's mirror so I can see the rear tire, and thus the smoke. Ideally you'd put the car in manual mode and just burn out in one gear. Then you have to remember to put it back into gear. :) If I have stock front tires, I drive around water and back in the middle, and then roll to the front edge. Our rear ends like a little lube.
For the groove sometimes folks will help or you just have to do the best job you can. I suck at lining my own car up at night at GLD, I second guess myself like crazy.
If you go and see Brad in the wheelchair "Wheelz" you can always ask him to help check if you are straight. Tell him John Ryan will give him a back rub when I see him next.
IceCreamAssassin
When in doubt, throttle out
12,572
17,164
Cary
I have the basics down. Also have a line lock installed now so the burnout should be much easier. It's more of learning my car in general. It's just a lot to remember... I don't have a trans brake but do have a 2 step and a trans controller.
So I need to...
- Do burnout with line lock
- Pull up to first bulb
- turn on trans controller and put in 2nd gear
- hold 2 step button
- mash brake and gas at same time
- hopefully the car rolls till second bulb and then stops
- let go of 2 step button and brake pedal at same time
- let rpm's climb a little then turn trans controller off so it can shift normal
It's just a lot to remember till I get a routine down, I've practiced a few times on the street, but I'll still get nervous.
IceCreamAssassin
12,572
17,164
Cary
So made it to the track today. Kind of hot but whatever. Did an 1/8 mile hit and blew the maf out again.
So then thinking I was done called Bob at Next Gen and he told me to stop being a pussy and find some duct tape. So I asked around and got some….
That’s a personal best for me and this car so far. Definitely easily has 9’s in it and I’m super happy.
Went back and tried turning it up but the tape wouldn’t hold anymore no matter how much I added.
So I’ll get that fixed and try again sometime.
