so this is the one i am considering pulling the trigger on. however, it was said that plug access is total shit?I bought it used off a guy semi-local. It's an offshore cast log, it was cut and the T4 flange lowered but works well for my application. Pic stolen from ebay, just search "LS turbo log"
If your going to drive it in the winter I’d use the flex fuel stuff, winter blend can be 50/50 anything over 70% dosent make a huge difference but 50% will, I got some that was like 40% a couple years agoGot the swap done, turbo kit is ready to be installed, just wondering about fueling as we go forward. I currently have the car roughly tuned on 93 pump gas, but when the turbo is installed I'm wondering if it's worth it to just go to straight E85 for the safety factor. Flex Fuel doesn't seem to be an option since I only have the 2 bar / 3 bar option available for my PCM. Still need to check the hardware #/OS, it's the factory PCM out of a 2004 Express van.
I'm wondering if I should just fill it up with E85 and tune the VE now, so that when I'm done installing the turbo kit I can just work on the boost fueling (PE/BE) and enjoy it. I've never messed with E85 so I'm not familiar with the general ignition and AFR targets. What's a good starting point for 10-14 lbs on E85 for AFR scale on an AEM UEGO, and what can timing start at? I'd just go and read plugs from there to see how it's liking it. This is purely a street car so I'm not looking to wring every ounce out of it, just want a safe fun setup that I can hammer on all the time.
Here's what my '04 Express P59 shows currently - already did the OS swap to a 3 bar.
Looks like Flex Fuel is already present in the tune, just need to enable it and tune VE/timing?
Do I just say fuck it and tune it using the normal VE table and straight E85 all the time? Will the variation in alcohol content with different blends and times of the year cause enough of a difference to affect the tune (cruise/WOT)?
I use those OEM metal heat shields on all my plugs and they were rubbing the casting in most spots. I bolted the log up to an old shitty 317 head I had laying around and just kept at it with a die grinder/burr until there was ample room around it. Probably a couple hours total invested.so this is the one i am considering pulling the trigger on. however, it was said that plug access is total shit?
and tons of casting seams inside the primarys? not that its a huge deal, ive got a die grinder...
I believe you should be able to fit two 450's with the stock hat and T them together.Thanks. I've had good luck with Dekas, is there an intermediate jump up from the 80s, or are the 210s the next step?
Can I just tee the fuel pump outputs in the tank? The stock hat just has the 1 typical 3/8 quick disconnect nipple for the feed.
Dedicated power source for the 2nd pump so I don't burn up the wiring? OK to run both pumps full time? I don't run the tank below half...
Please tell me you’ve seen the Roadkill/Roadkill Garage/Faster with Finnegan shows and their jaguar (draguar)?The more I worked on the car the more I realized how uncomfortable I would be putting a freshened up motor and trans in a car that was starting to rust out. The body was ok on the exterior but the passenger compartment floor and trunk floors were really getting bad, along with some spots on the frame. I probably could have spent a ton of time grinding rust off and playing the POR15 game but didn't think that would really net me a big return on my time invested.
So, I pulled the body off the frame, sold the 8.8 and IFS, and am parting out the rest.
Enter the Jaaaaaaaaag.
It's a 1984 Jaguar XJ6 that was owned by the PO for almost 2 decades, and doesn't have any rust at all. He babied it as a weekend cruiser and had a bunch of pricey service done including refreshing the rear brakes/bearings (weirdo inboard IRS setup), new tires, and a new paint job. Conveniently, the stock 4.2 I6 cranks but won't run due to the overly complicated fuel system and questionable compression numbers and leaks fluids profusely from the engine and trans. Yes....excellent....
Loaded up the ole family truckster and went to snatch it. Towed excellent once I unbolted the driveshaft from the rear diff and rat shit strapped it up out of the way.
Since this is all a one man show I needed a way to pull it up on the dolly. Welded a HF worm gear winch to one of their 2" receivers...
I will have to upload some more pics of the Jag but overall it's a ton of car for what I paid. The plan is to:
-Fix the oil pan leak on the 6.0 and figure out how to convert the FEAD to be a little lower as I refuse to cut the hood on this car (truck intake won't fit).
-Teach myself to rebuild 4L80E's and put the good guts from the broken case into the good case I have that had broken guts in it
-Most likely ditch the stock 04 van PCM and standalone harness. I have never enjoyed using HPTuners since I first picked it up 5 years ago and am ready to make the jump to the ease of the TerminatorX
-Build a fuel system with enough headroom for E85. It's going to be a fuel cell since the Jag has a crazy twin (but separate) tank system. Still trying to learn about the pros and cons of in tank vs external pumps, filters, etc etc.
-Regear the diff, I believe it has 2.88s in it now but is based on the Dana 44 so gear swaps are not impossible.
-Burnouts?
