do not recommend going back to stock chain with those springs. Additionally, I learned the necessity for proper valvespring pressures with my turbo car this year. Heavy springs should definitely help you.
Kevin's car has never had head gasket problems with MLS gaskets installed. I have felpro, and they work. I prefer to have a "fuse" in the system, so I prefer to have a head gasket go instead of hard parts like pistons.
Having a good clean and flat surface on heads and block is key to making MLS work. They have specific RMS surface roughness values to follow for optimum performance. Could deck the block and get some more compression, especially if the car is run on E85. This does end up with more low end torque, which a FWD car can't really use anyway... but it is a good way to make more power.
